Thanks. Yes, all stick welded on my AC buzz box.Is that all stick?
Very nice if it is
Very nice if it is
The earth clamp *is* a suitable thing to strike off.Criminy! Give your earth clamp a break and stop using it to strike off on, get a suitable piece of metal for that job!
Looking at how neat the welds are I might give it a go myselfAnyway, this welder came from my dad after he retired. And he had already started the trend!
Me too - I’d be well happy with thoseLooking at how neat the welds are I might give it a go myself
That made me chuckle ,One of the most difficult fuel line replacement on a chainsaw ever View attachment 466696
The small engine repair shop gave us just normal fuel hose, wrong length, wrong size, extremely tight fit on grommets and barbed fittings.
Didn't provide the formed hoses so another pain .
As I've had to work with short hoses in thigh spaces but I did it.
Replaced impulse line, the diaphragms and primer bulb too.
Already too late to tune the carb or attempt to start it.
But I've pressed the primer and I've not discovered any leaks.
Tomorrow we'll see if it runs and if the carb needs adjustments (I'm sure it does as they usually need little adjustments after those kind of jobs but I might be lucky)
Blistering Barnacles!That's why we took the clamps off the production welders and bolted the work return directly to the work bench.
That's quite a distance to jump tooA Brazilian jumping spider, only found in Brazil, apparently!
I was making up some chainsaw chains outside, it was a bit chilly so I got the firepit out.
Not seen one of these spiders before, what is it?
