Can't see the pictures mate, can see the icons but not the pics. of your work.More did than made, but today, determined to gee myself in spite of this 'bug', I went out to the shed [all the weather's fit for] and did this. They've been annoying me for ages lying about on the bench! The magnetic tray with all my spanners etc will fit neatly to the left of the holders but I've not got a pic of it in place.
But what an ar*e of a job!!!! I was glad my neighbour had loaned me his rivet gun, instead of having to use my big 'lazy tongs' one.
Really awkward access, then I broke the 3mm drill for the mounting holes. Regrind, then crack on.
No!! Broke again [working at an angle to get some holders mounted] !! Ground another drill and pushed on - finally all drilled. Then to riveting. Got a few in then nipped the flesh of a finger in the gun.[Do you think I could sue my neighbour? ] Finally all in place and another job off the list.
Then I realised that the sleeve of my jumper had conveniently wiped the bed of the lathe of oil, so it's in the washing machine for the next wash.
These things are sent to try us, and they do.
I can see the emoticons but not the pictures.Can you view the 2 pics? The emoticons were the result of the copy/paste I did from another forum post and weren't compatible here I suspect. I've corrected that now.
Try right clicking and opening in new tab?
There's nowt between the image tags.
I've tried editing with redoing the pics. Can you see them now?
Looks from his 'like' that TYA could see them first time round.
A new drain cover.
What finish are you going to put on it ? If that's mild steel, won't it surface rust? [at 6mm it'll take a good while to rust through ]
View attachment 182054 View attachment 182055 Needed to make some special M140x3mm nuts. Lathe was busy so did it in the milling machine instead...
