Memmeddu
- Italia Sardegna
Finally I've replaced the cord and riassembled the welder ,I've cleaned it from all the dust that was inside using a little brush and hand air pump
As you can see in the images
The new cord is longer and thicker ,the plug is new and finer to see
Hope you can see the heat shrink tubing onto the cable where the cord holder bite into the cable itself
I put it to give more strength and prevent the cable to bend
Replaced also the black pg11 using a white pg13,5
And grounded the chassis because wasn't fitted any ground PE cable onto the machine
I found that using heat shrink tubing as cord saver makes good esthetics and give a feeling of good job done so I will do this often in the future when I will work with flexible cables or power cord or extension cord
Maybe also on welding leads expecially at the end of the electrode holder where the lead get bent practically always
Hope you like my efforts to improve little bit my welder
I haven't cranked it on so I'm little bit scared to have did something wrong but surely I will not catch on fire so not a big issue
