DAPPH
as dyslexik as I'm daft
Still not got the tubes rolled by the boatyard but I did get the front sliding door made and welded in place.
Down,
And up.
Also was going to be welding some tabs onto the hex bolts of the 220mm stainless clamps so a spanner wasn't required as they will be removed at least once a day but then decided to put a wing nut on the opposite end and weld in place. That means they can still be used with a spanner if require, only thing is they can not be dismantled but that won't be a problem for this application.
A friend then came in asking if I had any bits of aluminium he could take home to fashion some sort of trolley out of. It is for his son who has a joinery business and often has to struggle up the side of houses with patio doors and double glazed units. I said instead of him messing around with grinders and hacksaws that I could just cut it on the plasma. He told me what he was thinking of so I drew it up in Fusion360 and once he was happy with the design it got cut on the plasma and welded up. Still have a clamping mechanism to make, I have an idea or two but he will have a word with his son to see what he thinks would be best.
Ok the quick model drawn in fusion, it consists of two bits of 3" x 3" x 1/4" angle, a flat plate to give the width and a couple of sides where twin wheels will be mounted on an axle.
A few minutes on the plasma and a bit longer welding and this is it so far.
You might find a pair of the cheap Chinese ...... eBay 150 or 175 mm dia non puncturable softish yellow rubber wheels are useful as they can go over a four inch kerb & gravel without too much effort when loaded up
You might also need to put a decent set of sealed for life bearings in them and studlock the nuts on the split rims bolts . I had to do that on mine as they often came undone & the supplied bearings were very playful & graunchy after a few months of use.
