The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
Modern PVC cloth covered 3 core cable.Is that a modern safe version of cotton covered three wire rubber sleeved cable Ardy ?
Lovely spalting in the timber , there is a woman somewhere in the UK who is an expert in setting cut lumber so as it get the best spalting occurring in it , as a result her guided timbers are rather expensive . Think there is you tube video with her showing some of the better specimens too.
Just found this UK video about home spalting " woodworking # 77 how to spalt wood 2, part 1 of 3 - YouTube "
I've started clamping my clamps to the rafters above my lathe so the long legs are over the lathe high up out the way , so far I've not dropped one on the lathe as it's always a two handed exercise putting them up or taking them down.
It's Creosote! But just neat.Is that modern "Creocote" or the proper stuff mixed 50:50 with old engine oil to make it go further?
Don't let us stop you, but have one back!By God there's some talent on here! I could spend all day just giving likes.
Pretty sure I could smell that here!Talking of smells. I dug out the cultivator from the shed for the first time in 35/40 years , cleaned the carb and filter bowl , new fuel and it fired up 2nd pull and ran perfectly but filled the garden with smoke for about a minute . The best bit was that I used to put a drop of Castrol R in the petrol and some of it was still in the system . The smell was FABULOUS .
View attachment 286591Made this yesterday fitted the timber today just have to paint the timber when I get some dark grey for it
No it’s solid as a rock there’s bracing where can’t be seen and it’s all 50mm box with 30mm heavy wall bracingWould that benefit from some cross bracing?
That's from?Back to primer to fix numerous cockups
Two more thin coats of primer
I added 1/35th black basecoat to the first, not a massive change in tint but enough to notice, if/when it needs sanding.
The front recessed bit, where I spilt paint then burnt it with heat lamp, has caused me so many problems. So, sods law, as soon as Id primered it today, a thick black hair landed in it. Not mine I dont have any! A blade got it out and another spray hid most of the damage.
