Dr.Al
- Gloucestershire, UK
Another bookmark to your site added
Do let me know if you spot any mistakes!
Screenshot:
Thank you
That will be very useful
If you ever write one for bike sprockets it’s would also be handyI’ve often wondered what a plasma one would be like vs a shop bought one. Obviously you’d have to profile it a bit on the lathe but a few afternoons at the mx track buggers them so the ability to cut my own would be damn handy.
I was not but I am now thank you very much.There is little point in going to splines. If someone is going to use the dxf for cutting a gear on a CNC machine, the G-code that the machine accepts only understands straight lines and circular arcs. So whatever mathematical representation of the involute you use, it will be converted to one of those in the CAM.
A very good addition to the program would be the ability to produce a dxf of a pitch-shifted gear, so you can alter centres or have different size gears meshing on the same centres (this is how the Gamet dual dials work - a 125 and 127 internal gear, but cut on the same pitch circle. It can also be used to make a metric thread dial easier to use; a 35t and 36t gear cut on the same pitch circle). Look on khkgears site for info. on pitch shifting, and being Japanese, they use metric units so your blood pressure will remain steady.
Are you aware of the document here: https://gizmology.net/sprockets.htm that shows you how do draw one in CAD. See also: https://sprocketeer.software.informer.com/2.0/
Went to pay my car insurance
Gave two of my buzz boxes to a guy who certainly needs them much more than me , didn't wanted nothing for them.
Hopefully someday I'll receive my reward .
I do like to help people
Yes I doYou believe in Karma like me then. What goes around comes around is the hope.
It looks great but what is it for?Second one done. Used the orbital sander against the sides to vibrate it down this time.
Typically I did only 75% of last time's mix (when I had too much left over) and this time was a bit short! Scraped to the sides and filled the hollow in the middle with a nom. 4:1 mix, no lime, no dye, just whatever it picked up from the drum. Was a bit sloppy tbh. Fingers crossed!
Makes sense now
Isn't "pitch shifting" the same thing as "profile shifting" (which is already supported). If not, I obviously need to do more reading!
Drive my car after almost a month .
Much longer gears ,much more power.
I've also had to disable steering assist (electronic servoassist) because way to light compared to the other car I was driving.
I have to delete throttle pedal for a while driving it like the other is way too fast
Traumatic , I'm almost scared about sitting in my car
Sorry if you've posted them and I've missed/forgotten the post(s)
