All I'm going to say, is you can have have too much torque. A lightweight car that simply lights its tyres up when you apply a mm of throttle is funny the first 60 seconds . . and absolutely useless ever after. Seven style cars thrive on revs and handling from a low polar moment of inertia. Confuse that by overloading it with torque, and power, and granny on her way to the shops with an open tray of eggs on the passenger seat in her 1.2 Fiesta will humiliate you around roundabouts, or in anything other than bone dry conditions.
Admittedly her Fiesta won't sound as nice
Where is your ce mark
I'm working for someone elseWh
Made in your workshop, doesn’t matter.I'm working for someone else
Their problem, not mine. I'm selling labour, not steel.Made in your workshop, doesn’t matter.
Nice resto, also nice head on the beer.This £5 vice was a fun restoration and showed the New MIS members that something that looked like it was well past the saving stage can be brought back to life.
A nice, but in a poor state.
Seized.
Broken.
Missing parts.
Badly rusted and pitted.
The screw thread nut was broken.
The front of the fixed jaw was also broken. But did allow easier access the pull the nail out holding the spring.
To open remove the moving jaw. Soak well oil, warm the fixed jaw up as much as you can.
Then drive in shaped wooden wedges between the fixed and moving jaw.
Drive home and walk away.
The forces and the drew will start the jaws moving.
The Nut was brazed up to repair it.
That is not another crack on the RHS, just a casting mark.
Replacement jaw made from scrap bar. Hand drilled.
Then case hardened.
Crush some hard wood charcoal into powder, heat the bar to red heat and cover in the powder.
All 4 jaw screw holes were striped. 2 before I got the vice. The last 2 by me when removing them.
So they are drilled and taped to M10, the suds are then filled flat and drilled and taped to M6.
On the final leg.
Down side of gold leaf.
It will show up any flaws.
Oh well.
Thank youI got fed up with the fact that every time I googled for "gear calculator" to remind myself of the equations for involute gears, most of the resulting links seem to be stuck in the dark ages of diametral pitch and inches. Rather than doing something sensible like keeping on searching and then bookmarking one that used the module system, I made my own (it also generates DXFs or SVGs of the gear profile).
Link: https://www.cgtk.co.uk/metalwork/calculators/gears
Screenshot:
Another bookmark to your site addedI got fed up with the fact that every time I googled for "gear calculator" to remind myself of the equations for involute gears, most of the resulting links seem to be stuck in the dark ages of diametral pitch and inches. Rather than doing something sensible like keeping on searching and then bookmarking one that used the module system, I made my own (it also generates DXFs or SVGs of the gear profile).
Screenshot:
Screenshot:
Thank you
That will be very useful
If you ever write one for bike sprockets it’s would also be handy I’ve often wondered what a plasma one would be like vs a shop bought one. Obviously you’d have to profile it a bit on the lathe but a few afternoons at the mx track buggers them so the ability to cut my own would be damn handy.
I was not but I am now thank you very much.There is little point in going to splines. If someone is going to use the dxf for cutting a gear on a CNC machine, the G-code that the machine accepts only understands straight lines and circular arcs. So whatever mathematical representation of the involute you use, it will be converted to one of those in the CAM.
A very good addition to the program would be the ability to produce a dxf of a pitch-shifted gear, so you can alter centres or have different size gears meshing on the same centres (this is how the Gamet dual dials work - a 125 and 127 internal gear, but cut on the same pitch circle. It can also be used to make a metric thread dial easier to use; a 35t and 36t gear cut on the same pitch circle). Look on khkgears site for info. on pitch shifting, and being Japanese, they use metric units so your blood pressure will remain steady.
Are you aware of the document here: https://gizmology.net/sprockets.htm that shows you how do draw one in CAD. See also: https://sprocketeer.software.informer.com/2.0/
