Sorry, I've obviously missed this, what's this for?Rebuilt the rotator /log Turner,with 1 new bearing and housing,as the driven sprocket was out of alignment with the driver I counterbored it 3 mm ,hope fully stop the chain snapping .ill try and remember to photograph it installed in the saw bed,the saw itself is a belter.View attachment 298546
Turning tree trunks for quarter sawing,they have 3 of them ,saw takes logs up to about 7m.Sorry, I've obviously missed this, what's this for?
Look forward to seeing this !Turning tree trunks for quarter sawing,they have 3 of them ,saw takes logs up to about 7m.
Put a steel plate behind the wood strips ...... for security as strips can easily & quietly be removed by any number of methods.Thanks for that Paul, I want to keep it in keeping with the look of my garage so I’ll find some wood to clad it with. I may do it like my shed. I’ll see.
Add for those that don't know ........ the volatile oils from bees wax are highly flammable & at hotter than boiling water temps can/will self ignite , use a non flame heat source such as an electric hot plate & a Bain Marie set up and don't leave it unattended for any reason unless you turn the heat off and move the containers to a cooler surface out of strong sunlight .^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
That's not all the wax from 2 hives, just some of it.
Opps my bad.
Same building the rakers were for?Made some piles of stainless, and also made some holey plates. (had help with the plates). 20mm bad Bois, way overkill, 12 would have done... But we paid someone else to make that decision!
View attachment 298558 View attachment 298559 View attachment 298560
So what are the hallmarks? I can look them up in my Bradbury hallmark book which will give the year and maker and assay mint where it was madeSilver, hall mark says so.
The green is from the copper pipe it was under.
I do like to rummage in box's at salvage yards.
Where there is muck, there is brass.
Beside, if it was plated, after that cleaning metod it would not be shinnnnnnnnny, or in use.
Do you bait it with anything? Just wondering what makes them go in. I’ve seen ones for wasps with beer in.A horse fly trap
The inverted bucket has a lid, which has a hole with the top of a PET bottle hot glued to it, the horse flies are supposed to get trapped in there.
YeahSame building the rakers were for?
