Liking that top bent bit of steel, how did you do that ?
Second photo.
Christ who do you use?every time I go to Hereford galvanisers,it’s a 2-3 week wait.Made this door the other day, dropped it in for galvanising Tuesday night and had it back and fitted today very pleased. Just need to establish how I’m going to clad it now.
View attachment 298381 View attachment 298382
It’s East Midlands galvanising. Part of wedge group. I used them before for my landy stuff. Really impressed this time with their speed.Christ who do you use?every time I go to Hereford galvanisers,it’s a 2-3 week wait.
That is what you call A Tool BoxMade a start on the workshop belated cleanup, not had a proper dung out/restock/wipedown in twenty years.
Cleaned up my trusty rusty slotted table, removed half of Surrey from the slots and gave it a large portion of scotchbrite, brake cleaner and maintenance spray.
About eight hours of putting away, at least a gallon of brake cleaner/elbow grease and it scrubbed up ok. Just need to go down the other side now
I've usually put 1/2 " of white spirit in a small tray & soaked the oil stone in it for 10 min or so then wiped the stone clean , done the other side then lightly oiled up with oil and a spray of WD 40 . Any cases got the white spirit treatment tooIn the picture below. Top LHS are two Stanley Yankee screwdrivers.
At first glance they looked ok.
The extended, they pumped.
But The bits were stuck fast. Turns out with glue.
This handle was set up to be striped and cleaned, but what the picture does not show is the split, the filler and the staples.
The other handle was as bad.
So, some beech, from a friends Fire wood pile was liberated. Turned down into new handles.
Test fitting here.
Fitted after paint.
2 more tools saved.
Everything in the top picture, bar one tool was restored.
The oil stones were very dirty.
So they were boiled up in washing soda for 2 hours.
The wooden cases were cleaned and waxed.
2 of the stones were curved, turns out they are knife stones, from a kit.
That is some serious workshop porn , I could only dream of having clear worktop space like thatMade a start on the workshop belated cleanup, not had a proper dung out/restock/wipedown in twenty years.
If your doing what I think and it’s for outside make sure it’s galvanised as the rust will come through the gap
That looks interesting .Second one done and he is thinking he may want another two
View attachment 298850View attachment 298851
As mentioned earlier they have barrels they use, if outside they just shove the micky mouse ears on and attach to the hose.That looks interesting .
Can you make a slip under deep tub C/W some sort of splash retaining lid with a water drain tap in the tank to hold enough water so they can be run up . Maybe putting the reinforcing webs further to the outside edges to give you more room ?
