I like those, I have only made a couple of acrylic pens myself. I am looking forward to getting my lathe back from storage and setting the woodshop back up
That is flipping neatThis is one of those jobs that took double my expected time.
Only reason being getting the shadow gap even and making the frame stiff enough.
Oh I built the bar aswell few months back and reroofed the changing room. View attachment 312594View attachment 312593
View attachment 312589 View attachment 312590
Took a good amount of effort to get the edgesThat is flipping neat
My guess would be shaper bit mounted on the cross slide. 0.2mm would be easily achievable without putting too much stress into the headstock bearings.Nope. All cnc
Wouldn't work on that kind of serration.Polygonal turning?
I reckon it was his Watford special.My guess would be shaper bit mounted on the cross slide. 0.2mm would be easily achievable without putting too much stress into the headstock bearings.
And it would be quicker than milling them. Slot will be done in under a second. A fine slot like that would probably take a few seconds to mill with a V/chamfer cutter.
Although polygonal could do the straight groove on one side of the circle, it would obliterate it as the cutting edge passed back out the circle the circle at a different point.
You could achieve a similar pattern by knurling, but you'd struggle to get it consistent.
NopeI reckon it was his Watford special.
Oh well no idea then.Nope
Bending forks.One of these bending things (whose name completely escapes me) which I've been meaning to knock up for years but have not until now.
Whilst doing it I also upgraded the breaker in my garage CU to a 16A type C, as welding it on full whack tripped the old type B.
She’s looking good for 96!
Don't over look the potential for the chair to be too low in the first place - I added some of these to all my mum's chairs - figured by the time I'd got the steel, measured, cut, made, painted . . . made a big improvement to her ease of getting up.My nan is 96 and has problems getting up from her chair, shes had one of these stander things but it wont work with her chair, it doesnt have a liftable cusion and the handles are far too high and too far forward.
So first change is fit the down tubes directly on the U frame. Plan handles to be bolt on so they can rotate to best position.
I got the feet onto welding bench.
Had 5 or 6 heavy showers and keep having to shift everything back indoors
First proper test of the wp20 watercooled torch. It works! Stayed nice cool at 100A and I wasnt feeling any heat. the cable is a bit short, and the tactile button I used is rubbish needs replacing.
Strange thing when I swapped to the wp17 at 60A, the back of my glove/hand/fingers were getting burnt and Im still not too sure how, or why it didnt with the wp20.
