Who makesthe kitchen units?they look really decentForgot to post these up. Not feeling great so with the frame system and that it took longer than expected 6 days
View attachment 313589 View attachment 313591 View attachment 313592 View attachment 313593
Multitool off the whole cill flush with the frame. Die grinder to remove all the rot from underneath. Resin up the rot with repaircare dryflex then glue/screw new cill in place and resin the joint to prevent future ingress"Can you just fill that sill while you're here..."
Not with all the Ronseal in Kansas!
Need to figure out if I can replace the sill without replacing the whole frame, I'll go back tomorrow with a die grinder and some wood chomping bits.
Howdens new inframe rangeWho makesthe kitchen units?they look really decent
Cheers. Other side of the bay was much the same.@eLuSiVeMiTe thats a pretty remarkable repair
They do a single tube version. Mixes on exit iirc.Very impressive, don't think I can stretch for dryflex though, looks like it needs a special skeleton gun too?
Link added to last postVery impressive, don't think I can stretch for dryflex though (Especially if I've got to buy a multitool ), looks like it needs a special skeleton gun too?
Looks better than the stuff used to fit 5years ago from HowdensHowdens new inframe range
Bookshelf/display cabinet on the island was made from end panels and the frame system.
Prefer fitting wren but Howdens are better for getting replacement/missing parts in a hurryLooks better than the stuff used to fit 5years ago from Howdens
Did you have to make any adjustments to the screw/bronze nut Dimensions?Finally scraped the cross-slide on my Harrison, just needs proper reassembly.
View attachment 313604View attachment 313603
Using a block to measure of the square as it is scraped.
Had a good amount to remove had to use a file to get the worst of it.
Some biax porn
@mtt.tr does it have taper turning?! Didnt spot that. Rare as rocking horse poop
There one on eBay but silly monehI thought it would be there is plenty slop so it fits.
It's missing the taper but that's pretty easy to recreate, the leadscrew is different from standard lathe
