I just use 2x 27" monitors, lot cheaper and if for any reason I need to conserve space I can remove one.
It is simple as long as your graphics card has two (or more) output ports, most do, even the cheap ones.I need to look into this, I don’t know how to set up two monitors.
I could see this being very handy
Easy peasy, and very handy. You just need a second video output on your pc, there may well be one on the motherboard and another on the GPU but both plugged into the GPU is better if possible.I need to look into this, I don’t know how to set up two monitors.
AyeI just use 2x 27" monitors, lot cheaper and if for any reason I need to conserve space I can remove one.
I'd dabbled with components for repeat items like windows etc but making a component out of components is a better option now I've used it. Take longer initially but saves time later making changes and laying out cutsThat is the way to do things in Fusion, wasn't used to that way of working with my previous CAD but once you get into the swing of it it makes life very easy for dismantling and placing for plasma or even milling.
Depends I split the screen and have a quote one side and invoice the other .or quote and webpage/doc I'm pricing fromAny good for documents and spread sheets?
Wish I'd done this sooner. Don't use it very often tbh but will definitely continue nowI make components from groups. It helps because I use Sketchup to make models to show demolition sequences and I can move/modify/delete bits to show the work progression.
Easy, assuming that your PC has more than one output, if not add a USB HDMI or Displayport adapter.I need to look into this, I don’t know how to set up two monitors.
.. an engine with an electric start for the lawn mower. Couldn’t get the old one off so it’s on the spare and running nicely, thank you very much.
You are a old hand, you know the rules.
Pictures, or it didn't happen.
No google images!!!!!!!!!!!!!!!!!
