Dieselman 63
Forklift Certified
- Wellington, New Zealand
A 3mtr long sink for the mancave, one side is heated so it can have solvent with a pump one side and rinse/handwash/kettle filling the other
don't fill the kettle from the wrong side, tea will taste funny!
Didn't see one in Braille ?I suspect @8ob will have that covered, with one of these on it.
https://www.google.com/search?q=eau...VjQkEAHRGxDwkQ_AUoAXoECAsQAw&biw=1024&bih=498
Fixed that for you, when they open I wont be going a mile down the road to the pub for a pint in my car thats on 15" rims then
Bob
Katsu stuff is pretty good. I have a Katsu router (looks like the Makita) which I've absolutely hammered and it's been faultless.Katsu die grinder.
240v powered - and again (as with the burnisher) much bigger and chunkier than i was expecting.
Not used in anger, but it seems solid, and well-built- and will do the job i bought it for (removing excess weld from internal corners in angle iron).
Just need to order a pointy-cone tungsten carbide bit now...
I'm open to hugs if I'm offered a "wee big dram of Jura"Do those hugs come in the size of a wee big dram of Jura?
Dyson DC27 Animal being thrown out at work. Hose disconnected underneath, seal missing out of the collection can and a build up of dirt blocking the vortex chamber from sucking up wet wallpaper then brick dust.
A strip down of all the vortex chamber that is not supposed to come apart, blow out, ultrasonic cleaner for the smaller bits and dishwasher for the bigger bits. £9.98 for the missing seal and a neoprene gasket so far and the filters are washable. Just waiting on the seal and then the trousers can give it a full road test and pull the remaining threads out of the carpet.
My HP cartridges arrived and the replacement head read two as damaged. Swapped the contact block from my original head and after a bit of messing about......
We have a DC8 (I think) and I repaired it with bits from another one. It wasn’t component failure but plastic fatigue making the handle brittle. Duct tape only works on the first few cracks! Same story with the head. It’s a hodge-podge of yellow, silver and purple now, but it does work...
Party logs.Picked up a couple of loads in the Arkansas Chuggabug today.
By the way she was sat down probably 2t
