brightspark
- yarm stockton on tees
I used toI often think that this pipe coiled in a filled water tank tucked in the corner outside would be as good as it gets regarding heat exchanging...ive found in the past even going through 10M of copper pipe the air is still warm and moist (ooer) if just exchanging room temps
when I was blasting regular I used a 5 gallon bucket of water and about 6 meters of 8mm copper minibore pipe coiled up in it and used it for my airfed helmet as the air from the comp was red hot and made you gasp with the heat . it was heaven when cooledI often think that this pipe coiled in a filled water tank tucked in the corner outside would be as good as it gets regarding heat exchanging...ive found in the past even going through 10M of copper pipe the air is still warm and moist (ooer) if just exchanging room temps
