Sergei Slovenija
- Slovenija Ljubljana
When I was a skint student back in 89/90, I bought a set of torx drives, long and short that fitted into the 1/2" drive adaptor that came with them, in a tin box box, all un-branded, from a stall on the market down The Moor in Sheffield to work on the Renault(s) I had - They've been used with pipes over tommy bars, with impact guns, lent to mates with no mechanical sympathy (with the impact gun, and a compressor to run it, so he could remove the rear suspension from a Pug 405) , hammered into rounded off socket headed screws . . . and still look in pretty good condition - the odd one looks a little twisted.I got a cheap Dormer Torx long set off eBay a couple of years ago of such security screw drivers that fit a 1/4 mm hex drive handle ratchet pistol grip or straight handle . Each bit is 100 mm long .& slightly slimmer than the screw head so it goes down any screw access hole easily . Very handy for taking smaller Dyson stuff apart .
I'm now after a triangular set in the same length .
Watch makers mini lathe ? Sit on the carriage when it'sto the left & it would be like going on a char banc holiday by the time you get to the right hand end .Acquired ages ago but finally got it home. 1908 dsg. Lovely big ol lump.
View attachment 340121 View attachment 340122 View attachment 340123
Has your new sensor not come with the housing then?
I've never needed to remove those screws as the new sensors always came with the housing as they're "calibrated" to the housing's bore/cross section. (Although people do swap housings on modified cars and such when remapping.)
I suppose you might remove the screws for easier claning of the MAF but that's generally in vain anyway.
They're an obscure tool for sure. I bought mine to "be prepared" but i got that wrong.
I used to operate the same model Arboga during my apprentice years. They are excellent machines but would be even better with a draw bar in the spindle.
I have acquired a milling extension for the small Myford ....
.... not from Rodney and also not from Amolco, but from Arboga ...
... also strictly speaking it is not an extension and it is not on the Myford, but a separate unit next to it.
The actual acquisition and removal I had already shown here.
Some things had to be rearranged in the house, now we finally got to build her up and put her into operation:
With the column one could think, it is only a "hollow round tube, why not just lift it up and into it" or also "what is this thin thing supposed to withstand?".
Well, the weight and strength is inside (sorry, no better photo).
This fat flat steel is welded into the tube over the entire length and forms the mount for the rack of the Z-axis on one side:
On the Arboga U2508, the head houses both the eight-speed gearbox and the 1hp motor, which makes it the heaviest and at the same time most delicate chunk.
Of course, we still have to hang additional lighting and we already have it in the house.
So off to the next adventure.
Wish everyone a good start to the new week
Carsten
What are they?View attachment 340618 nice hand written letter with them
Some kind of special clamps ?What are they?
Bead formerWhat are they?
