Dieselman 63
Forklift Certified
- Wellington, New Zealand
Would be far easier just to boil a kettle .....................................Yesterday I acquired this, well it is an extended loan for as long as I need it
Plasma cut a bit of 10mm steel to act as a hot plate.
That allowed me to put a 500mm x 400mm x 100mm tray on that I made so I can boil the water, took 15mins to get 10l of water to the boil so that is perfect
Doesn't make as good a brew thoughWould be far easier just to boil a kettle .....................................![]()
Tea urn not big enough sadly.I bought a 20l tea urn
Dunk a 12V submersible pump in it, connect to 12V, connect a parts washing brush and hose to the outlet via an cheapo water filter thingie, add suitable detergent to the amount of water you deem sufficient, and voila . . . heated parts washer.
Realigned that to save our necks.....Bought because I'm interested in the discharge feature (timed discharge down to pre set voltage). I'm planning on testing some lithium cells that I have to check remaining capacity. It also charges the batteries up too of course!
if that's for the drive it's tipped on it's a shame the driver couldn't have tailgated it for you. Then again I know you have toys to useTechnically is was Monday but the first load of stone for this job at home. Only another 350 tonnes to go...
It wasn't. That was for backfilling the trenches with the 6" rain water pipes.if that's for the drive it's tipped on it's a shame the driver couldn't have tailgated it for you. Then again I know you have toys to use![]()
Not today but a few days ago some smaller Milwaukee tools
Britool 26mm socket - a great find! Just 25mm to go and I have a complete set.
So jealous. I really want one of those ratchets.
Gonna need to do some DAF brakes now. Don't know anything else that uses 26mm.
a brace of Bosch Sortimos (empty) from a neighbour View attachment 340762
Arrived today a lead to read fault codes on older VAG group vehicles and a static Bosch VE pump timing kit
View attachment 340765View attachment 340766
