How much if not cheeky ?And I liked the last set of cutters so bought another pair, bit like pants 1 pair for best and the other pair not for best!
A very pertinent point.Now where are they going to hang their towel ?
An interesting idea, I'll give it some thought.
I'm not quite sure how I can/should measure and define my jaw chuck sufficiently in order to find soft jaws for sale (in the bay) ...
£15.00 pair delivered on ebay, think I had the last pair from that particular sellerHow much if not cheeky ?
My colleagues ones (no brand), are rubbish, priced up Facom side cutters 36 euros... Ouch.
oh yes I like the NWS cutters and pliersHave a look for NWS side cutters. German-made, excellent quality and not too expensive considering how good they are.
They're my favourites. I have a few pairs of NWS and they're all exceptionally good.
Company lives in Germany but item made in China ?Scheppach rings a bell, not the best, not the worst.
"And the trucks not bad either"
©Autoshite
You have a very good memory.A very pertinent point."And the trucks not bad either"
©Autoshite
Hi Maker. I did. yours look more akin to dental picks, mine are beefier than thosePretty happy with this lot.
Sykes circlip pliers, little box has tips of different angle and diameter, not as nice as a full set of Knipex ones but probably the best design for interchangeable tip pliers. The picks are Ullman, IIRC Shox raved about these a while ago, they certainly feel nice in the hand, very fine tips too. The tin on the left is a Sykes clutch alignment tool, I thought it was a tiny slide hammer but alas not. Not much use to me really.
Good to see you back mateHi Maker. I did. yours look more akin to dental picks, mine are beefier than those
If it’s no use to you I’d be happy to buy it from you. If that’s not too cheekyPretty happy with this lot.
I got a Sealy bench 9 inch shear about 25 years ago ,It cost me over £125 IIRC . I'd got over a thousand 150 x 200 mm rectangles of 10 mm steel mesh to cut up a bit better than after angle grinding them off the big panels . Cutting the small panels to a pattern to make observation tubes and places to mount the automatic drinker devices so I could start equipping our small mammal reading farm & get on rearing stock ASAP.A big box. It contained..
3 flute countersink, diamond bits
A tiny 1.5kg swivel vice. I am quite impressed with this. £6.
300mm bench shears. Cuts nicely, should be better after adjustment. £31 !!
The feet are not on straight and are warped up but I couldnt give a crap about that.
I dont think my wallet should suffer alone..
Manual Sheet Metal Cutting Shears 300mm
steel-plate hardened carbon shear blades cutting mild steel long handle sheet iron stainless steel copper capacity aluminium 4-5 mm steel capacity 0.2-2 mm blade length 300 mm manual metal cutting Handmatige plaat Platschaar metaal staal Cisaille de coupe manuelle à plat métal acier Manuelle...www.aimtools.co.uk
Rotating Base Mini Bench Vice 60 mm
【Multipurpose】 Ideal for wood and steel working 【High Capacity】 Maximum jaw opening is 50 mm and mounting clamp jaws open 45 mm max 【Convenient Design】 Swivels 360° to allow you to work at any angle efficiently and has a light weight of 1.6 kg 【Robust】 Manufactured from die cast iron 【Easy to...www.aimtools.co.uk
Countersink HSS Drill Bits 90 Deg. 6.3 to 60MM
HSS Countersink drills 90 Degrees. Suitable for mild steel, wood, plastic and other non hardened materialwww.aimtools.co.uk
