25.4_mechanic
- Germany, southwest
Would you be so kind as to put me on number 3, pls?I will be making a couple, I will put your name on the list.
Carsten
See what youv'e started
i normaly use a large bit of bluetac split it in 2 one on each end of the wire and stick it to a desk![]()
The two little wheels are spring loaded and hold the wire securely, the thumbwheel on the left adjust the distance between the two legs.
Put me down for one Graham...very handy tool thatOff the Snap on man, I will be making a couple, I will put your name on the list.
Can you stick me down as number (n+1) on the list, if you're making a fewOff the Snap on man, I will be making a couple, I will put your name on the list.
Problem arises when you’re on your back wedged up inside a lorry wheel arch minus a deski normaly use a large bit of bluetac split it in 2 one on each end of the wire and stick it to a desk![]()
Don't bother with those knurlers, the clamp type work much better, especially on small lathes. A "Cut knurler" is the best but you better be sitting down when you see the price.
If something is Anti-Rust Resistant then does that not mean it will easily rusttoday I aquired a laugh while browsing for a knurling tool
Seller No. 1) "no, I ain't no never haven't ever rusted":
and
Seller No. 2) "I don't give a flying rat's ass about you stupid customers, I despise you, I'm so uninterested in you that I don't even bother with the sales images":
... but maybe he just set the exposure time a bit too long when he took the pictures ....
© ebay.de = You know what you're getting.
Carsten
They do put a nice chamfer on the top of most screws . . . and occasionally undo oneIRWIN power grip screw extractors. A whole £1 on eBay and I even got the chance to take my bike out for a decent run to collect them. I didn't need them but at over £40 for a new set how could I resist at a quid
You didn't fancy one of these then?![]()
These clamp types are better. Kinder on the lathe bearings.
20 quid on UK ebay
Anti-Rust means it will not rust easilyBut instead?![]()
Im too tight to buy stuff so after @Kram kindly sent me some spare knurl wheels I made one
,a little bit more movement than I need
