angellonewolf
- bristol england
as long as there not hammers for @ParmI donnate to good life forms
I have two bags of thrupenny bits in uncirculated condition if anybody lusts after them. I took then out of the bank when they announced their withdrawal in 1971 and still have them.Haven't seen thrupenny bits for a long time !
Pay you dues, then visit.Hang on a minute, let’s not go there
I’m currently due a hammer and an axe !
I will soon. You knew my predicamentPay you dues, then visit.
I will supply them to you. Plus a coffee.
Failing that I keep them.
A veritable Aladdin's cave of goodies Carsten
I think I'm right with this :-
The counter will simply turn as the shaft rotates so it will be a few trials of seeing where the graduations line up . If it's no good for metric perhaps make a slip over magnetic cap with one marked point for metric if they aren't accurate enough & run in from a fixed carriage stop block so you know where the thread starts
Alas I do.I will soon. You knew my predicament
I can cut metric & imperial on my antique Atlas using the same thread dial indicator & lead screw , nothing changes save for the change gears . I suspect Carsten will have change gears for metric thread cutting on his Myford lathe .
see :- https://www.model-engineer.co.uk/news/article/metric-myford-threads/27223
Such gears 3D printed if not readily available appear to be good for many lathes , as they are somewhat strong There might be some on such sites as thingyverse etc just ther for th paying a small fee and getting thm printed .
I can get a full set plus extra's for the Atlas , but if I wanted I think I could 3D draw and print individuals in ABS without much difficulty . Apparently a lot of modern home hobby lathes are using plastic gears as well as a few industrial ones.
No, got the table and engraver working fine but not enough juice to power the plasma where it is currently located, I’ve some infrastructure work to do as well as changing 3 phase supply from 100amps to 200amps(just a meter and fuse change, supply already there) so may buy generator as temporary measure needs 26 kva I think.Have you cut anything yet?
Me too, Steve. It just isn't possible. Change wheels just give you the correct ratio. But, and don't quote me on this, the relationship between the TDI and the tool position is only correct every 127 turns of the spindle once you disengage the half nuts.
New grinder for finger callouses. Also good for abrading dirt out of your fingers. I needed to use the old one about 10 minutes after every climbing session, eventually wore out the motor, this has a bit more power to it.
Also comes with a razor blade skin peeler Nope. This bit will not be used.
What's wrong with a bit of sandpaper glued to the back of a hold brush?New grinder for finger callouses. Also good for abrading dirt out of your fingers. I needed to use the old one about 10 minutes after every climbing session, eventually wore out the motor, this has a bit more power to it.
Id like to try Winspit one day, mostly indoors on plastic this year. Its a bit too far away.Rock climbing I assume? We’re in Corfe Castle this week, youngest and his wife are hanging off of Winspit at the moment…
The 10 minutes would turn into hours!What's wrong with a bit of sandpaper glued to the back of a hold brush?
