Nice to hear. I thought I'd read some good things about Newarc stuff and also about using them for gouging, but after I bought it I couldn't find a single comment about them and I wondered if I'd made it up in my head!Newarc is decent gear. Had a 250a mig for years, the tig/mma gear is used on site lot, @Jim Davey knows a bit about them.
Is there a reason for this splinter thread when there is one of exact same name, with a few extra or less ....
As my befuddled old dad used to say - i know what I meantI think you've posted that question in the wrong thread of the two, or have they been merged?
A friend brought scraper plates, from the Soviet BK6-OM alloy. Sharpening on 8 edges.
It will be interesting to compare with Sandvik plates and other manufacturers from Europe.
View attachment 362095 View attachment 362096
It is necessary to build a grinding machine with a diamond stone...They look good. So long as they are micrograin carbide they should hold an edge. You can use regular carbide but you have to sharpen it more often. I have in the past used carbide slip gauges for scraper tips.
I also need to sharpen tungsten electrodes. A separate grinder is seen as an urgent need.You can do something as simple as sticking a cheap 1500 grit diamond lapping disc onto a piece of ally or steel with double-sided tape and holding it in your 3-jaw chuck. Run the lathe at 400rpm and use it as your shapener.
Thanks again. I've ordered a couple.
Free heat from our own land, cant get more locally sourced than that! energy companies can go swing!
