Blobber
- lincolnshire
I wouldn't knowLike cystitis!
"Birch and fir logs burn too fast
Blaze up bright and do not last"
Ask him to get you some ash!
That's not a very high bar...Its more comfy than it looks
>Clap<Like cystitis!
Keeps you warm twice!Its free and it burns!![]()
Ive got the "8kw" version and its certainly no where near that but wasnt expecting it to beInterested to know what the real heat output of this thing ^^^^ is. Diesel's energy density is about 10kWh per litre, and the claimed fuel usage of the heater is 0.1 to 0.24 litres/hr, so I make that 1kW to 2.4kW, so nowhere near the 8kW claimed.
The 300ml tubes are the small plunger, 410ml are the bigger plungerAlso aquired... A friend recommended Rawlplug R Kem 2 for bolting into concrete. Couldnt find my cheapy sealant gun and toolstation showed this heavy duty thing. Looks a lot better I thought. It was listed as unbranded and orange. When the guy handed over a silverline I almost rejected it!
Luckily I checked it when I got to the car. Note the issue.. the plunger at 54mm dia is a larger diameter than the tube of 47mm ID. However I decided it could be modified and kept it, which meant picking up another £7 cheapy for the current task.
The nose is also a bit small and will open up with die grinder. Lastly the body is slightly short, perhaps not an issue if the plunger fit properly
Are there any tubes that actually need a 54mm plunger?
