brightspark
- yarm stockton on tees
No nor me. Lots of home made bits there. Thought it might be part of a clamp.
Sure il find a use.
He had a big planer gauge too but couldnt find it.
Any idea on this.
Little grub near my fingers adjusts height. Some kind of measuring equipment I assumed.
Ain't got a clue. But had to have it.Lowest speed of 2800RPM. What are you going to use it for?
I will see if I can gear it down some.Ain't got a clue. But had to have it.
High speed drillingLowest speed of 2800RPM. What are you going to use it for?
12000 rpm top speed. HmmmHigh speed drilling
Nice bit of kit. They are still in use at the old Dunlop factory in CoventryToday I acquired.
This fantastic bench drill. Nice size unit that serious weight. View attachment 160394 View attachment 160395 View attachment 160396
High speed drilling
4mm and smaller.
It seems a little over the top for drilling pcb's!
Some one has geared it down previous. All I need to do is get some multi step pulleys and job done.
Yes mate I will indeed be doing a full strip and rebuild.Didn't take long for you to get into its entrails. Will you be doing a full refur'b along the lines of the lathe one? If so, I'll be following it with interest/admiration.
Ref. the nail puller - commonly called a Bahco 38 Nail Puller: the sliding handle is quite a loose fit on the main shaft. It is used as a hammer, sliding up and down to force the two jaws into a floorboard on either side of the head of a cut nail, and also can be extended to provide maximum leverage when pulling the nail out. I recently bought a load of floor joists from a Victorian house in Oxford. They were peppered with cut nails; the Bahco never failed once getting them out.
