So met with builder, welder and building control today. Explained all of my concerns, welder gets on the offensive and starts showing me pictures of the huge structures he's worked on and helicopter platforms he's welded on rigs and that he's worked on the Shard etc. He then starts giving me a lecture of how those welds would hold at least 60 ton etc. he would never put anyone in any danger.
Building control basically said, there is weld there, and the standard of weld wasnt his concern, yet I am the client and if I was not happy then I must go with what the engineer advises, not the welder.
I then speak to my engineer, who quickly sends through a sketch of a solution with 2 angles bolted/welded (properly) either side. Welder then concerned about how he will get into the space to do that and starts giving alternate suggestions that are pointless, like welding a plate to the underside of the 2 incoming beams, completely missing the point! Chippy and builder trying to work out how to cut the floor and roof joists away etc to allow access, I'm now more concerned that this idiot is suggesting he is going to remediate it, and potentially set fire to the place in the process, so I stop the circus and reconsult with my engineer to suggest a less desirable yet easier solution which would be to weld an angle from the column flange to underside of beams to provide additional bearing as the current one on the plate is only a few mm. I've subsiquently left the engineer now to work out a solution to this taking into consideration the potential bending effect on the "undersized" column installed and await his outcome.
I've now spoken with the builder in private and told him I do not want that welder doing this remediation work and want a graded welder or someone who knows what they are doing on the job, such as a reputable fabricator. I've only watched 3 YouTube videos on the subject and can easily now tell the difference between what is a decent weld and isn't.
I then come back later in the day to find the welder has filed the welds back to make them look tidier and painted them red! Wtf is that all about?
I'm now awaiting the drawings from the engineer to move forward.
Is there anyone in here that knows where I'll find a decent welder in the North East? Must be loads given the ship building heritage?
Thanks.
Thanks.
