DIY MIG welding
Home MIG TIG Arc Paint Forum
Welding Supplies Direct
Welding: The DIY Guide > MIG > Techniques
MIG Welding Techniques and Tips
This section is a bit of a mix. It covers some essential techniques for car bodywork welding, and also some other aspects of DIY welding machines.
Thin Metal
Blowing holes in thin metal? MIG welders aren't well suited to welding steel under 1mm thick.
Here's a technique that should be good for 0.6mm sheet.
Welding thin metal
Gasless MIG Welding
You can use it in the wind. A page with pros, cons and techniques.
Gasless weld
Plug weld
Plug welding is a DIY alternative to spot welding. It's a useful technique in automotive repairs where the panels were originally spot welded.
plug weld
Finishing Welds
There's only one way to end up with the invisible welded repair and it doesn't involve your ordinary angle grinding disc. This one is a real welding secret.
Finishing Welds
Welding thick metal
Manufacturers claims of welder capability often seem exaggerated. The Clarke 90EN claims to be capable of welding 4mm steel sheet, but the calculator says 2mm. The page looks into the techniques required to achieve the claimed thickness.
90 amp welder
Tips and tricks
A few random thoughts and techniques that haven't found a home elsewhere in the tutorial.
tips and troubleshooting
Next: DIY MIG Welding > MIG > Brazing, Aluminium and Cast Iron top
MIG Welding Index
MIG Tutorial
Techniques and Tips
Welding thin metal
Gasless MIG welding
Plug welding
Finishing welds
Welding thick metal
Tips and tricks
MIG Welders
Shielding Gas
Practical MIG Welding
Welding Different Steels
Weld Testing
Useful Info
© Copyright: MIG Welding - the DIY Guide. Please notice the disclaimer and the privacy and cookie policy
