Setting wire feed speed
Wire speed is probably the most important setting on a MIG welder. This page is intended to help you fine tune your wire speed and includes a video to demonstrate what the different speeds sound like.
Many wire speed adjustment problems are due to wire feed set up issues, so it's worth checking that page if this one doesn't help.
Technique
It's possible to weld neatly at the wrong power setting - penetration might be too little or too much, but the welds can still be neat. Get the wire speed wrong and it can become very difficult to weld at all. The trick to finding the right wire speed is to experiment.
Adjusting wire speed on the fly while welding a scrap piece of steel is a quick way to test. Set the welder to approximately the right power setting for the thickness of metal, start welding, and while welding alter the wire speed knob until you get somewhere near.
Video
In the video the wire speed has been gradually increased from very slow to very fast. The captions at the top show where I think the wire speed is too slow, good, and too fast.
Be sure to turn your sound on - the sound of the weld reveals what is happening more than the images. There's a control at the bottom of the video you can move to listen again to each segment.
Guide to video
Off
The wire feed starts at zero. It takes a little turning to get it going at all.
Far too slow
The wire is making occasional contact with the metal, but as soon as contact is made the wire burns back (forms a ball and melts back to the contact tip).
Too slow
The wire is still burning back after contacting the metal, but the process is repeating more quickly.
Good
The wire is going fast enough to give a constant arc to the metal, and there is a nice consistent sizzle sound to the weld. (said to sound like bacon frying, though I fail to replicate the sound with my cooking. Maybe a more expert hand holding the frying pan might get closer.)
Too fast
The weld is still consistent but but the crackle is starting to sound fierce and the penetration is increased. Cheaper welders might start making a machine gun like noise at this point.
Wire speed actually controls welding current (the power knob on the welder only sets the voltage). Increasing the wire speed past the point where you achieve a nice consistent weld will only increase the current and can cause blow through on thinner steel.
Far too fast
Here the wire is moving so quickly that it bends as it hits the metal. The torch feels like it is being pushed away from the metal, and there is a lot of spatter.
Wire speed tips and tricks
- Generally for thinner metal the wire speed is set at the lowest speed that welding can take place smoothly. This is because the current actually reduces as the wire speed is reduced so thin metal can be welded more slowly and controllably.
- It's possible to reduce wire speed further by reducing the distance between the contact tip and the work piece. This can cause the tip to overheat, grip and stop the wire, and ruin the tip, but it can be a useful technique for delicate welding such as end on to an edge especially if an oversized tip is used or when welding for short periods.
- For welding into a corner increase the wire speed. This reduces the length of the arc and makes it easier to weld directly into the corner rather than arcing against the sides.
- Wire speed will need to be increased slightly when welding on a vertical surface vertically or to the underneath of a horizontal surface.
Wire speed control and different welders
Wire speed will need to be increased as the welder power setting is increased.
For DIY MIG welders the wire feed is usually independent from the power setting. On these welders the wire speed will have to be manually increased as the power is increased. For my Clarke welder running 0.8mm wire a speed setting of 2.3 was good for the lowest power setting, and 5 worked well on the highest setting.
More expensive welders normally have automatic adjustment of wire speed - the speed is changed by the welder when the power setting is altered. On my Portamig 181 a setting of 5.5 is good for both low and higher power settings, and the wire speed knob is only there to allow tweaking.
