DennisCA
- Finland
Imageless update, but I have been working on the vertical head, the t-slots have got burrs in them and that makes the t-nuts get stuck in the slots. This is because of abuse and torquing the screws too hard. I have seen people modify the t-slots, they make them slightly wider and make new and bigger t-nuts that are kidney shaped to fit the slot. With the increased surface area from that you reduce the risk of damaging the slots again.
That's a future project I want to take on but for now I ground the burrs out using a dremel style tool and fine diamond grinders that cannot remove material quickly. I have been working very carefully, only a little at a time so it took some time...
Though I have inferred how the head works and these surfaces are not the important ones for registering the rotation and centering of the vertical head, that is done on the innermost face. While I got rid of most of the burrs sticking out in the T-slot, I did not want to keep on grinding there, so instead I turned down the round part of the T-nuts a little, just enough to remove the black finish and that was enough, now they all move freely in the slots. I will have to be careful about tightening them too much.
Anyway I believe that is enough of that. I have to finish up this pin wrench I am working on to reinstall the nut that retains the X-axis nut. It also took quite a while because I was cheap and made it from several scrap pieces I have welded together (then turned, welded again), just because I did not want to use up good, limited stock!
I also bought a surface plate, I still want a 630x400mm one but this one should last me for some time before it becomes too small:
Granite surface plate | FINE TOOLS
Based on my own math and info from the Thome website, it qualifies as DIN 867 grade 00.
