DennisCA
- Finland
I've been spending the last few days on shop reorganization. The mill and lathe now sit like this:
Today I worked on the electrics for the FP2. I decided to add another 3-phase outlet to the electrical box. That way I won't need to run a cable for the lathe and can plug both mill and lathe to the same spot.
The additional outlet is not hooked up to the switch but is always live if the electrical box is hooked up.
Almost everything is hooked up. One really weird thing is the yellow cable that goes to a regular 230V outlet on the front, I tested the terminals it's hooked up to and it's hooked up phase to phase (!), so anyone plugging anything in there expecting 230V will get 400V single phase. I have no idea what the previous owners used this for, but good thing I didn't plug in anything.
Regarding the color scheme on the cables, it's not the modern standard and I decided to reuse old cables and hook them up using the same color scheme to keep everything the same.
I also removed this transformer to make room for the 3ph outlet. I am not sure if it's original or what purpose it served. It's a 230 - 100V transformer but only 100W. Not sure what need I'd have for that.
I also re-routed some of the wall outlets, fortunately an easy task since the cables are all just held to the walls with cable clamps and not hidden. I decided I really don't want to have a cable across the floor so I routed the outlet to the ceiling instead, as close as I got it, then I will drop down a power cable to the electrical box.
