What's a really good blade?That’s the Axminster saw, takes a little bit of setting up and a really good blade to make it a good saw.
Yes, m42 blade dose the jobWhat's a really good blade?
Its just 1" dia tube about 450 long, plates are 40 x 5 flat and the stand offs 12mm solid, just made from what I had lying around, I used to make loads of them using the pre made parts when I had a local hospital contract,Paul ,
Is that in 44 mm easy to get proper marine grade polished stainless tube where you can also get right stainless angles with mounting plates & cappings to fit a elongated U to a wall . I'm thinking of putting an extra stainless steel horizontal grab rail on my wet room .. concerned that most bars especially the Chinese tat currently flooding the market appear to be steel tube bent at the ends , copper plated then plated in chrome that eventually opens up to rusting.
Dave
Why do they have removable ends? I’ve never seen them before
Ahh that makes sense.To save you having to carry the whole key with you everywhere, suit didn't have suitable pockets. Ours had a small hole in them so that they could be clipped inside a key case.
That tit on the end is probably the same idea?
Wash yer mooth oot, thats nae way tae talk aboot Slim....
This was damaged by it being attached to a spiral key ring round the small bar, the tit on the end is the knob of a spring loaded plunger that locks the key in position on the shaft
