addjunkie
- Northumberland. Reet oot in the sticks
yes…..fair point, but you did need to build the power stations of what ever flavour first, using the dead dinosaurs to power to build them.If you were to begin using oil, for the first time, right now, think how fantastically unbelievable it would seem to do so.
First, you need to go and find some dead dinosaurs from millions of years ago, probably under the sea somewhere.
Next you need to build some structures, many thousands of tonnes of steel, with all sorts of fantastically complicated processing equipment onboard. These need to be capable of being sunk down to the sea bed and then drill down into the pockets of dead dinosaurs.
Once you’ve drilled down you need to extract and separate the crude, remove any water etc and then pump it onto a ship specially built to transport it to somewhere else. You might also build a pipeline hundreds of miles to transport it.
The next step is then to refine this into products you can actually use, using huge amounts of heat and chemicals in specially made plants costing many billions of pounds to build and run. You’ll need to then transport this product using a fleet of specially made trucks to stations across the uk with big underground storage tanks where you can then pump this stuff into your vehicle.
Makes putting some fast chargers around the country seem quite tame really.
