Thats basically what I did...the Tucson warranty is about to run out so wanted to replace it....so the choice is a new petrol/diesel/PHEV or EV.We paid no premium for an ev, we simply spent the same money we were going to on a petrol/diesel car on an ev.
Something wrong with the maths, there - if you are able to get ~3.5miles/kWh, then 100 miles requires around 28.5kWh which, at £0.56/unit is £15.96, so 10,000 miles a year would cost £1596.Just googled.
A typical EV does 3 - 3.5 miles on a kwh.
1 litre of petrol is somewhere between the equivalent of 8.9 to 9.7 kwh.
(If Google stuff is close to correct).
No idea what that means without some thinking & maths.
OK...
If 1 litre is somewhere around 9 kwh,
If you get 3.5 miles per kwh, then to do 100 miles you need about 11 kwh?
11kwh @ £0.56 per unit is £ 6.16, which is still only just over 6-pence a mile fuel cost. Is that about right?
A newish petrol/diesel car doing 50mpg, & with fuel at £1.55/litre would need about 9.1 Litres & £14.11, so just over 14-pence a mile fuel cost.
Over say 10,000 miles a year - it's £616 fuelling for the EV, versus £1410 for the ICE - a difference of £ 794 cheaper for the leccy car.
If home charging at say 32p per kwh, Then 11kwh is £3.52 for 100 miles, & £352 for 10,000 miles - so £1058 cheaper.
Am I therein thereabouts?
If you can charge at home you should pay ~ 9.5p per kWh on a nighttime tariff. Depends on area and supplier but that seems about average currently, we had 7.5p last year and before that it was about 2.5p!Thats basically what I did...the Tucson warranty is about to run out so wanted to replace it....so the choice is a new petrol/diesel/PHEV or EV.
If I'm honest I'd pay a bit more for an EV just to get away from the whole petrol/diesel pricing nonsense.
Cheers thats good to know...is that easy to setup with any provider?...it's a 64kwh battery so I make that £6.80 per 270 miles?If you can charge at home you should pay ~ 9.5p per kWh on a nighttime tariff.
I thought I might mess up. I got bogged-down in the idea of comparing kwh to litres & gallons & confused myself most likelySomething wrong with the maths, there - if you are able to get ~3.5miles/kWh, then 100 miles requires around 28.5kWh which, at £0.56/unit is £15.96, so 10,000 miles a year would cost £1596.
This assumes that the 3.5miles/kWh is the mains power input equivalent i.e. it includes the energy conversion (charge/discharge) efficiency of the battery and the 90-95% cefficiency of the charging circuit. If the 3.5miles/kWh is based on voltage and current measurements at the battery terminals during discharge only, then the true "EV fuel" costs would be higher, because of those inefficiencies.
I cant get it, as our smart meter is dumb as it doesn't communicate, being* a very rural area. We are disadvantagedThat night tariff is very cheap. I think mine is 16p
Thats what was putting me off too...but the MG4 is £32k so quite a bit cheaper to begin with. Their warranty is 7 years so basically I'l be keeping this car quite some time. The alternative was a £34k PHEV but the mpg was terrible on the motorway unfortunately.But a 40k EV will depreciate by I dunno, what, maybe 10%
64kwh etc.Cheers thats good to know...is that easy to setup with any provider?...it's a 64kwh battery so I make that £6.80 per 270 miles?
Petrol prices really annoy me because they just seem to charge what they can get away with...I can't wait to be free of that nonsense!
I'm also quite interested to see how its going to work out. I'm not really pro EV...just made sense. Think I'll do some monitoring to see what's what and report back.I for one would be very interested to hear from you just what you find out, & just what you actually get from your kilowatt-hours
Youll need your connection checked by your dno too, when you install a charge point at homeI'm also quite interested to see how its going to work out. I'm not really pro EV...just made sense. Think I'll do some monitoring to see what's what and report back.
Today I learned (on here) that I basically need to home charge on an EV tariff !
Ok, rambo. Why did you specifically write that it was a problem for EV vans. Get real, you were trying to demean the EV van just to demean all EVs like all your posts. Writing without thinking or writing to try to get people on your side. Disgraceful.
Otherwise you cannot have a hope of knowing whether you're comparing apples with apples, or apples with foot powder (model to model) .... or just how real your storage KW are.... till you get it home & do the maths in use (& not rely on what the Dash tells you..... & I suspect 99% of customers don't do their own checks/calcs)
Nowhere near if home charging - if you are vaguely sufficiently clever enough to select a more suitable tariff. My current tarriff is just under 19p/kWh for virtually all my charging needs. There are cheaper tariffs and my electricity usage is far less than most (until I include the EV charging). I am getting 4 miles/kWh over the last 550 mile, or so. I pay 18.93p/kWh, so 10k miles would cost rather less than £500. I could (and may well) change to another tariff of either (currently) 9.5p or 7.5p per unit. That could halve my 10000 miles energy cost to to as little as £188 (possibly less) but may adversely affect my household energy cost.
I am holding off making my decision re supplier and tariff, at the present time, because my wife has not long to live, so my personal circumstances are bound to change in the very foreseeable future. I could, eventually, change my car for a smaller, more fuel-efficient model, but likely will not - as the AWD and towing capacity are useful assets.
One thing I will not do is revert to an ICE vehicle (I am still running a diesel car, although it does not get much use) I expect (am aiming for) eventual regular trailer usage/availability, behind my EV, thus allowing me to sell the diesel vehicle. Winter is approaching and household electricity usage will rise considerably due to less solar generation and other electrical loads.
Currently, I have more to worry about than piffling vehicle fuel costs, but I would like to think that I am doing my best to reduce fossil guel burning. Also doing my bit in reducing urban pollution. Apparently (and quite clearly) not priorities formanysome on the forum.
Watts is the internationally recognised SI unit of power and therefore demands a capial letter, not lower case abbreviation.
One litre of petrol may contain about 9kWh of energy, but nearly 3/4 of that is wasted energy (non-motive). As the grid becomes less reliant on fossil fuels, the difference in wasted energy (compared to EVs), by using ICE vehicles will inevitably rise. In all ways, fossil fuelled vehicles will eventually cease to exist as economical personal transport. Get used to it.
I think you'll find quite a few EV owners do their own calcs - they have accurate records of power supplied by their chargers, a large number of them are logging the data and every public chargepoint that they use is as well. EVs can not only record the miles but the power breakdown of the usage per trip which can be quite interesting.
If you go to https://ev-database.org you will the nominal capacity and the usable capacity of each EV, there isn't a massive difference between the two for most manufacturers, not sure who is the worst culprit. Modern EV batteries behave very differently from lead acid and manufacturers are backing their batteries with decent warranties thanks to their massive data sets collated over many years which give them the confidence to do so. C rates charging are more of a problem than C rates discharging on road cars thanks to the general publics desire to try and get energy into the cars in a similar timescale to refilling an ICE!
