Onoff
- Sevenoaks, UK
You are all responsible for my lack of self control.
My punishment is not being able to use mine very well!
Why so? They do Stanley and Impax brands, all 5 star reviews. I’ll try a pack next time I’m passing as I’ve got a trade voucher to use up.i find screwfix rods next to useless i usually get mine from wasp welding cant remember the brand redline i think and nearly the same price as screwfix
Hi thanks for the quick reply. Little more confused now lol. He did say tig torch to positive. Unless I’m understanding it wrong.Stick on DC can be electrode positive or negative depending on the type of electrode and what you are doing, DC tig is always torch negative,
Welcome to the forum
Thank you. Plenty of food for thought here. Cheers.I like to run 6013's Electrode negative also referred to as straight or DCEN, electrode positive is known as reverse polarity, but read the pack or look up the spec, some electrodes are quite fussy, others less so try it you may not even be able to tell the difference,
As I said TIG is torch negative, the bloke in the shop is wrong connecting the tig torch to the positive will destroy your tungsten fairly quickly.
So if you were using this ALDI welder with a 6013 stick which way would you recommend. Also if setting up for tig which way for torch. Thanks
But it's good fun when people come and lean on your bench and you have HF start....As I said TIG is torch negative, the bloke in the shop is wrong, connecting the tig torch to the positive will destroy your tungsten fairly quickly.
This cheapo Aldi inverter MMA welder...if I wanted to try TIG with mine and added a cheap torch would it be VERY wasteful on gas in that the gas flow is constant and doesn't stop / start.?
Cheers
