I have always wondered why a roof is so dark. It would make a big difference making them reflective - perhaps changing to dark for the winter.
Cities would be a lot cooler and it would save on vast amounts of energy.
Particulates in the atmosphere can reflect a lot of heat - hence the term nuclear winter. Also volcanic eruptions can have the same effect.
PV cells have efficiency peak in the visible wavelength. The UV and IR regions of the spectrum have only a small contribution.
Photosynthesis happens around blue and red (450 and 650 nm).
The introduction of PV cells doesn't change the rate of heat absorption or transmittion, but we're now converting visible light (that would have previously been "inert" to the planet's energy balance) into electrical energy. This will inevitably lead to a greater net energy input, and ultimately warming of the planet.
No, you're not wrong per say. As has been mentioned as most panels are very dark, they'll absorb more radiation than a whiter surface. They, in big expanses, will also "insulate" the earth from radiating some of its energy away to the night sky and reduce ground wind speeds. Resulting in local heat island effects.
surely if the panels are insulating the ground it does not get as hot therefore does not have the capacity to radiate.......
I'm eating a prawn sandwich for lunch.
Unbelievably, it has over 35 individual ingredients!!
What on earth is the environmental cost of getting all that stuff grown, processed and moved to the sandwich factory?
Then it has to be taken to the garage and kept in the fridge that's running flat out to maintain 3deg in 28deg weather for me to drive in my van and pick it up.
That's just the ingredients. People are driving to the factory to operate the sandwich machines and then there is the packaging not to mention that I also have a bag of crisps and a can of drink.
This won't be the only thing I eat today and I will probably continue to eat every day for as long as I can.
The couple of solar panels I own are probably not my greatest impact on the sustainability of the planet.
And the prawns were probably cought by slaves on Thai 'ghost ships'..In fact, people in general are the problem.
white or black body absorption and radiation is net neutral.... reflected and it heats up what its reflected at, absorbed it radiates the same heat later when the equilibrium changes, the net heat is still the same... roughly
white bodies warm slower but also radiate slower....
Like I said, roughly.....Hmm, good points.
It's been a very long while but isn't the reason that it's not a net neutral effect because, while whiter objects absorb and emitt less, dark bodies absorb more higher wavelengths but then emitt them at lower (IR and the like) wavelengths which, unlike the higher wavelengths, warm the surrounding air more readily? So that while of course emission/absorbtion is in balance, the net effect is a warmer local environment if you surround yourself with black things.
Like I said, long time though so happy to be put right.
Exactly so. Exacerbated by trapping even more of it.And we can’t get rid of it back into space, so it makes sense that the planet is warming up, because of all the energy it is absorbing.
We are trapping more energy than the same area of earth would have been under agriculture or forests etc.But we are not trapping heat, heat is reflected off
What we are is capturing light
Yeah….. we’ve been great at things like this without understanding unforeseen consequences.The way that we could stop global warming is by stopping 7% (ish, this was what it was discussed about when I was at uni in 2004 -2008) of the light (or electromagnetic radiation) hitting the earth, this could be done by solar shading like a small number of satalites blocking the sun. Or as was suggested on one lecture the application of milk powder to the atmosphere (this is not exactly going to work but it was suggested) Alternatives were doing things like painting all roads white and all rooves white its a thing called the Albedo effect
My array is doing the earth more harm than good, but individually, we as a family are doing well out of it.What's the crusade?
I would fully support anybody who said the science shows global warming is real, is bad news, and should be stopped if possible.
At the same time I'm not going to get rid of my fridge and walk down to the nearest farm every day to get a pint of milk in exchange for half an hours farm labour then return to my house and heat it on a wood fire.
You do seem to be doing more than me by having a 10kw array and using it to charge your car up.
But I'm going to carry on driving my diesel van around to work until I can afford to buy a house big enough to put a 10kw array onto
Just been reading, the sun delivers more energy to earth in one hour, than that delivered by all the fossil fuels we consume in a year.
Perhaps our scientists/engineers should be looking into ways of collecting energy in equitorial regions & transferring it to more temporal/colder regions. Probably more doable than creating fusion reactor generation.
RonA
