tflnemesis
I have been having some major issues with mine over the past few days...
It started when I noticed my bed needed levelling again, no matter what I tried I couldn't get it level.
I ended up completely stripping down the bed mechanism, tried various configurations to sort it, but what helped the most was widening the holes in the carriage plate to 4mm as the screws between the bed and carriage plate were binding.
Then I noticed that one corner of the frame at the front wasn't resting on the surface the printer is on. Naively I thought ' I'll just bolt it all down'... Big mistake!!! It knocked everything out! So I had a think after unbolting it and ended up shimming the whole printer wherever it needed ( All the support material I had saved came in very handy for this.).
I tried a print and it printed poorly, the part was complete but the amount of stringing and deformation was atrocious.
I had noticed a rattle when it was printing and set out to track it down... After a process of elimination I tracked it down to the 'Y' guide rods having up to approx 1mm movement in the holes where they slot into the frame. It seems shimming up the frame had removed all the tension in it and now the play in the rods is showing up.
This is where I am at atm, If I had a lathe I would just drill out the holes and turn up a bush. I think the easiest solution for me is to use some epoxy in the holes to take up the slack. As the bed shouldn't move in the Z apart from the usual amount caused by the machine moving I think epoxy will be up to the task, but, ofc I don't have any epoxy as its all been used by Mr Nobody again. I am gonna have to start charging the guy rent because he is costing me a fortune!!
Once I have got the above done I will spend a session re-calibrating it, especially the extruder because I think it is over extruding atm, although the roughness in the print might be down to the amount of play in the guide rods.
