Westfield-builder
Wikes didn't come up with the 'use upside down can' it has always been used like that.
yes that looks ok seen far worse and yes you always use the can upside down, you could silicon it or use the pvc trim how wide is the gap
Supply problems?yes I have a gun too so much more control over the foam.
I think I would use silicon on the sides it will be so much neater just tool it nicely.
Q. how come you didnt foam the top?
How best to neaten it up? It looks to big to cap with silicon, so some neat edging seems the best way.
As a rank amateur, I'd source and push/glue in hardwood strips, then go over the gap with frame sealant of the appropriate colour [white in your case]. I understand from a pal who retired from the building trade that it won't dry out or shrink.
I'm sure the Collective will tell us if this'd be a good idea....![]()
these are used now https://www.amazon.co.uk/Faithfull-FAIWEDGE100-Plastic-Packing-Wedges/dp/B01BMV32PKAs a rank amateur, I'd source and push/glue in hardwood strips, then go over the gap with frame sealant of the appropriate colour [white in your case]. I understand from a pal who retired from the building trade that it won't dry out or shrink.
Cheers.
Trying to use an aerosol upside down was not the best idea Wickes have ever come up with.... you can see on that last pic how easy it is to miss the orange ‘this way up’ line around the base of the can.
I fitted a PVC door & had to make up the width with battens down each side, I got some bull nose cover strip from a building plastic supplies & glued it on. I had to cover a bigger gap than you have, but it made a tidy job. There is bound to be a supplier near you, be worth calling in to see what they’ve got. I tried to take a picture, but with the white on white it was difficult to see
Foam gun and screw in can work much better much more precise.I just been my dads house, and around his back door and window (1930's house) there are trim strips of various widths, all glued to the frame and looking quite neat. The installer must have used the proper UPVC adhesive, rather than the white silicone I would be using if someone hadn't mentioned it here.....
Maybe so, but in my experience of using expanding foam aerosols, which extends to one can, ten years ago, this upside down thing is a first. And the one I used before was the correct way up to squirt.
I actually bought two back then, and one has sat in various sheds for ten years or more, and needless to say it didn't squirt anything at all when I pressed the end in.![]()
Yeah squirty foam is useful but it needs firm hand and a cool head ...or maybe it's the other way around ....I have used it for a few jobs ... seen it used or many jobs where someone should have had a quiet word with the 'handyman' involved ...I watched a local guy here in Crete try to glue the hinges of a shed door to a stone wall with a can of foam .... He was convinced it would be fine ....I find the trick with it is to use half what you think you will need and have a plant sprayer with water to keep the foam damp ... and then walk away ... Then trim it back with a new sharpe clicky out stanley knife things the next day ....
