123hotchef
- Kent
are you sure the is not a retaining wire ring like a circlip insie a grove in the cup you have cut
Nothing to lose but getting a rag to wipe the grease off and have a close look before heating anything up...Seems like you have nothing to lose so I would try heat and an air hammer placed onto the back of the joint close to the shaft as possible without marring it in the process and give er wa
Pretty certain the circlip is inside the joint not visible outside...could I be wrong???
Yes I have the new cv and a new clip... it fits inside hidden away from mere mortals like us lotDo you have the new CV joint, if so did it come with a new circip or what can you see in there?
They are on any I used to do...Pretty certain the circlip is inside the joint not visible outside...could I be wrong???
