addjunkie
- Northumberland. Reet oot in the sticks
There is a simple solution to such jobs, it begins with a phone call, and ends up with an invoice to pay!At least you could get to it. Try changing the starter on a JCB 2CX.
There's an access plate in the side of the engine bay which is inaccessible if the loader arms are down. Even then you pretty much have to do everything left handed as that's the only one you can get in.
Once you finally feel where the nuts are you then find you can't get a socket on them because there's a special CV jointed shallow socket they made to fit in the groove they machined out of the casing. You can get a spanner onto two of the three but the third doesn't have enough space. You then have to cut a 15mm spanner in half to make it fit, remove the coolant expansion bottle and lie on top of the engine to place said custom spanner on the nut. Go underneath, carefully place a small pipe on the end of the spanner taking extreme care not to knock it off and then **** it with a sledge hammer to crack the nut off. Once knuckles babe been suitably skinned you can then return to lying on top of the engine to use two fingers to undo the nut 1/12th of a turn at a time at which point you drop the nut into the mud because that's always where they decide to break down.
Once you have undone the three nuts and disconnected all the wires which are all conveniently JCB yellow then you can proceed to pray that you can squeeze it past the 3" hose that feeds the hydraulic pump from the tank because if you can't that means draining down the best part of 22 gallons of hydraulic fluid.
Oh and the wings are 1" plate and you can't remove them.
. I took the whole lot out before I figured the problem
