badabec
- Essex UK
I fitted the exhaust, filled the tank (half full), started up, get error code 03. Great. Took it all apart, contact cleaner on all the plugs, dried with air line. Back together on bench. Started it up, error code 09. Look in book of words, error codes only go up to 08.
Pump is not pumping. Has voltage at plug. Pump runs if connected to battery. Won't run when plugged in. If I manually fill the pipe with kero, it fires up and runs OK. But the pump won't run.
The heater is connected to a car battery, which is also connected to a battery charger.
And I threw the box away....
