gaz1
- westyorkshire
ive looked at your numbersGaz1, not sure if this will be of any use to you but see below my figures since my system went in.
Garage is 3.87KWp (50 degree angle) and caravan port is 10.24kWp (8 degree angle), bit further north than you are looking for so anything comparative is likely to give higher outputs.
but your caravan numbers dont add up right via the very first total 2018 dec
200 then it gives 3850 that number dosnt add up even if it was right it dosnt match up up either with yearly too either nov/dec numbers either
