Just a few.plenty of nails to pull out the grate!
I use a magnet with a quick release handle.
Carrier bags are pretty strong 30kg in there!
About a weeks worth.
Yeah, my daughter has no gas in her village. She used to heat solely with wood, two stoves 12kw and 4kw. She got through tons. Now she has an air source heat pump for heat and hot water. Stoves now just supplement this.You use far more than that if you rely on wood only. That would last me 2 weeks tops.
I once went through 2 full artic loads of logs in 1 year when I lived in the Brecon Beacons. Yes that's 44 tons of wood!
I wouldnt like to see her leccy billYeah, my daughter has no gas in her village. She used to heat solely with wood, two stoves 12kw and 4kw. She got through tons. Now she has an air source heat pump for heat and hot water. Stoves now just supplement this.
I have a steel plate over my grid too. Wood just needs air from the top. It burns too quick with air from underneath too. Only coal and smokeless needs a grid.On one of the burners I replaced the grate with a solid sheet of steel. I never burn coal on that one so dont need the grate, and cleaning out is real simple with a flat sheet base - just slide a shovel in under all the nails occasionally.
I've never bothered with that "leave a bit of ash" thing. I think that kind of thing is for people who want to plan out a fire, rather than just chuck in wood and get warm. 5 mins after lighting there's ash in the bottom anyway!
Her leccy bills are fine. The KW quoted are her wood stoves. The air source heat pump is super efficient, it's supplemented with solar panels. Apparently it uses 1kw of electricity to produce 4kw of heat!I wouldnt like to see her leccy bill
I can add more to that oneI have unlimited supplies of free pallet wood - not the planks but the thick side bearers and blocks.
Whatever you do dont burn MDF - very nasty chemicals and it stinks.
but say if you was getting it delivered would you buy from your heap stacked or would you want a pack stacked ibcI don't stack I just chuck cut and split logs in. Ibc is 1000 litres. Usually I have them heaped about a foot higher than the top.. As they're randomly chucked in, and air can get around them, I think they season better.
I disagree with the blue pallets bit they aren't that bad. What you have to avoid with pallets are the pressed wood blocks. They stink and the binder used in them is very nasty I only burn the solid wood blocks.I can add more to that one
never burn blue pallets
never burn mdf as stated above
never burn osb board
becareful of hard board
interesting subject here
you can burn pellets and wood shavings but you can also burn wood shavings and sawdust
i use the under air to get the fire going good fast its ok using the top air but faster to use underneath when your getting the wood coals hot in the first placeI have a steel plate over my grid too. Wood just needs air from the top. It burns too quick with air from underneath too. Only coal and smokeless needs a grid.
If I was buying I would want it tightly packed!!!!.but say if you was getting it delivered would you buy from your heap stacked or would you want a pack stacked ibc
not forgetting its your place once its delivered to restack it or would you just cover over a topped ibc container of wood
sorry to the op but as you may see theres more to just having a wood stove
its also down to costs and also down to whats in local areas
Its a shame some of you guys aren't a bit closer, I give away so much firewood.
Bob
Oil is much cheaper than buying wood.I'll add my thoughts.
What is the cost of good firewood in the U.K.?
Here it's not cheap I pay £200 for three meters cube of oak / chestnut.
Pellet burners are all the rage over here, but not my cup of tea.
We have a Rayburn, an Invicta wood burner, best wood burner I've ever owned, and a cheap mild steel wood burner too, yes, when it's cold we have three fires going in three chimneys.
Steel welded burners heat up quick, but cool down quick, cast iron heats up slowly, keeps the heat and cools down slowly, best for keeping in over night, depends how you run them, and the wood you burn.
These are the only heating in our house, and it's pretty huge.
