Wendelspanswick
I have used both, all 8 forges in the Guilds workshop at Cannington were water cooled back draught but the portable forges were dry bottom draft. These dry forges were used for shows and roped in as extra forges during competitions.Thanks very much for the offer but it a little far for me to travel and probably awkward to transport. Also the build is half the fun.
I am struggling to decide witch is better bottom draft or side draft. What are the pros and cons with either.
The problem we found with the bottom draft forges is the clinker* sinks to the bottom where bits of it are constantly being blown back up on to the workpiece, unless you wire brush the workpiece constantly it ends up with a blemished finish. The clinker tended to block the perforated bottom plate as well.
With a back draught forge the clinker sinks below the level of the fire, the workpiece needs a lot less brushing and results in a more blemish free finish.
As apprentices we used to hate using the portable forges and during competitions where apprentices from all over the country would come to the Guild forge us 'local' apprentices would bag the permanent forges knowing that the visiting apprentices would get the portable forges. Home advantage every time!
Clinker, a red hot sticky mass that forms at the base of the fire when forging and is normally removed at the end of the day when it has cooled into a solid mass. The clinker is a mixture of all the impurities from the coke and the scale that falls of the workpiece, it's like red hot toffee and is a bugger to remove if it cools on a workpiece as it is as hard as glass and sticks like s**t to a blanket!
