daleyd
- Wrexham, North Wales
I worked for 9 years for a company that made thermal oxidisers, yeah very similar. We used to sell a variant that was just a burner chamber - even with preheating combustion air it used a lot of gas to keep the temperatures up.That's interesting to know, sort of a cross between a Regenerator in a old-school Blast or Open Hearth Furnaces, and a Recouperator in a Thermal Oxidiser, or Fired Heater.
The glass industry is one of the very few I haven't had very much contact with, so it's cool to learn more about it.
The RTO type with ceramic beds were very very efficient - especially if you had a process where there was enough solvent to run itself. Once up to self sustain temp then the burner got switched off and the process air was enough to run the oxidiser, if not then natural gas was injected into the process air stream and burned in the beds, which again was more efficient (by a long way) than using a burner and combustion air.
RTO typically use the same arrangement of flow reversing to prevent the heat from being pushed out of the beds.
