Hi again everyone things are progressing quite well I have taken the motor in for inspection/repair and it is "£$%^&*ed I have been searching the net for a replacement and the best I have found is £129.00 the details of the motor I have removed are
RPM 2800rpm
Shaft diameter 28mm
Shaft length 60mm
Frame 100mm
Foot across front 160mm
Side 140mm
Height to shaft centre 100mm
2.5 kw
3.5 hp
16 amp
the one I am looking to replace it with are
3KW / 4HP SINGLE PHASE CAPACITOR START & RUN 2800RPM 240 VOLT MOTOR
MOTOR DETAILS
HP --- 4
KW --- 3
RPM --- 2800
AMPS --- 18.2
SKF BEARING
IP55
FRAME --- 100L-2
MODEL NO --- ML100L-2
CENTRE SHAFT HEIGHT 100MM
SHAFT LENGTH 60MM
SHAFT DIAMETER 28MM
CAP START & RUN FOR HIGH STARTING TORQUE
ALL MOTORS COME WITH A FULL SET WIRING INSTRUCTIONS, MULTI MOUNT FEET & CAN BE FITTED WITH A B14 OR B5 FLANGE ON CUSTOMERS REQUEST AT A SMALL EXTRA CHARGE OF 8%.
ROBUST ALUMINIUM TERMINAL BOX
DIRECTION OF MOTOR CAN BE CHANGED BUY THE SIMPLE MOVING OF 2 COPPER LINKS OR SWITCHED THROUGH A FORWARD REVERSE STARTER FOR USE WITH ROLLER DOORS ETC
MOTORS WILL BE SENT BY TNT ON A 24HOUR DELIVERY IF PURCHASED BEFORE 11.00AM
Can anyone see any reason why this would not be suitable or even better where I could obtain one for less money as already this has turned into a dear project but I am in to deep to stop many thanks Chris
RPM 2800rpm
Shaft diameter 28mm
Shaft length 60mm
Frame 100mm
Side 140mm
2.5 kw
3.5 hp
16 amp
MOTOR DETAILS
HP --- 4
KW --- 3
RPM --- 2800
AMPS --- 18.2
SKF BEARING
IP55
FRAME --- 100L-2
SHAFT LENGTH 60MM
SHAFT DIAMETER 28MM
