Hood
I am obsessed.
- Carnoustie, Scotland
Not really going to be FLOOD coolant thenJust collect the coolant below in another can and drop feed from above
Ok central heating pump it is then what kind of filter do I need and what type of coolantNot really going to be FLOOD coolant then![]()
it doesn't need to be flood just a constant small flowNot really going to be FLOOD coolant then![]()
Flood is better if you are wanting to stop the thermal expansion which I think was the main point of considering getting coolant.it doesn't need to be flood just a constant small flow
in industry but not realy in a home workshopFlood is better if you are wanting to stop the thermal expansion which I think was the main point of considering getting coolant.
But that was what was being discussed here, tapped hole going tight once cooled. Flood coolant was suggested as an alternative to removing from chuck and getting on drilling another etc until they had cooled and could be rechucked and tapped.in industry but not realy in a home workshopno rush
What is better. Is that a 5 to 10 percent mix of water or coolantThis is a decent cheap coolant I have used although I now use their synthetic.
https://www.ebay.co.uk/itm/LUBESOL-...190985?hash=item43bf4b4909:g:G4UAAMXQAI9SKEyH
20L lasts me at least a year and I have 3 machines running it, well 4 if you count the beaver mill but that never gets used now since I got the Chiron.
The manual lathe uses the most as it gets splashed about on that. The CNC lathe and the Chiron hardly use anything as they are fully enclosed and they actually need topped up with water due to evaporation more than they need topped up with mix.
I would say you would be best with about 20L although smaller would likely be fine.
Yes it would be 2L of oil to 19 of water although likely that would be to much. I think normally when I was using the semi synthetic it was about 1.5L I used.
Edit
typo with the amount I said 1 rather than 2 but fixed now. Also it is probably more 20L of water as I just fill up a drum and they usually hold more than 20l. You don't have to be precise but I usually use the scope to get it to the mix I want.
