we shall see soon enough!Definitely the best way to go, well as log as the quality is semi decent.
Il let you be the guinea pig before I buy.we shall see soon enough!
I may be able to rig something up to the milling machine and use the same pump. Pick the mill up SundayIl let you be the guinea pig before I buy.
Can use on all my tools with a little work.
What millI may be able to rig something up to the milling machine and use the same pump. Pick the mill up Sunday
Tidy. Already had a mod to help it keep register too.This one. View attachment 191898
Pretty much the same as mine.
Easy enough to whip the table off for a good clean
and walls and floor and youThat iso 68 will be lovley to use for drilling. Does a cracking job of stopping rust too, all over your machines.
Has a couple of other cool mods too. Single lever parallel locks on the column and y axis, so you don't have to fiddle with the screws...Tidy. Already had a mod to help it keep register too.
Round up some troops again!Thanks @julianthegypsy the lathe is safely home but it is staying in the truck for a while!
