Sorry to hear that, could not be sure of the condition of the parts from your photo's. If there is any damage, to the spool/sleeve/housing bore faces you get leakage and the valve is scrap.Big fail to report. Just as bad. Feel quite down about this. I have spent hours on this tractor. Same as above - 3.5 - 4 whole turns of the wheel to the right over a straight 0.3 mile bit of road. It's really not driveable on the road.
Thanks. Very frustrated this evening!!Sorry to hear that, could not be sure of the condition of the parts from your photo's. If there is any damage, to the spool/sleeve/housing bore faces you get leakage and the valve is scrap.
You'd need to measure the components with at least a tenth reading micrometer or better, on a comparator that you've set with slips.Thanks. Very frustrated this evening!!
I thought everything looked pretty good but I am guessing the tolerances are so fine that looming good might not be enough!
I thought with the issues found I would get a better result tonight!
Try slightly slackening the column bolts and see if it makes a difference, unlikely though can cause problems.I'm not sure how the steering column could be misaligned on this. I bolted everything up with the steering lines disconnected (I.e. valve set as per the manual in the resting / all open position. I was quite careful to slip it onto the column without moving the valve from where I had set it as per the JD manual).
I jacked the front end up at about 9pm and there's a fair bit of play in the steering joints - esp the TRE on the right. I can fix this bit can't see it being the cause of this issue.
Will give it a go. Thanks!Try slightly slackening the column bolts and see if it makes a difference, unlikely though can cause problems.
should make no differenceI had the wheels straight ahead when I connected the hydraulics too in case that is important .
In my head it's possible but why would that be so one sided? I'm always correcting to the right. (Not saying it isn't, just trying to understand) .Could a failed internal steering ram seal give these kind of symptoms?
swap the left and right steering hoses and see if the problem changes sides - if it does its the steering valve, if it remains the same side its likely the steering ram seals.In my head it's possible but why would that be so one sided? I'm always correcting to the right. (Not saying it isn't, just trying to understand) .
Front ends on axle stands at the moment so can push the wheels around.
Thanks for that. I was so fed up last night as I was convinced I had found the issue.I have no help to give you here as I know nothing about hydraulics or tractors but I've been following this epic thread and hope you can get it fixed. @Rannsachair seems to know his stuff so hopefully you can do it in the end
I know how you feel though when you think you've found the problem and put it all back together and it still doesn't work! I have a shower pump doing that to me at the moment![]()
Unfortunately old worn out valves are not what I know, I have designed and developed new steering valves, and designed test stands for them.I have no help to give you here as I know nothing about hydraulics or tractors but I've been following this epic thread and hope you can get it fixed. @Rannsachair seems to know his stuff so hopefully you can do it in the end
I dont know if I will be able to drive it like that- it will be back to front? I have to be doing fast walking pace on road to really feel it. In bouncy fields on grass it's hard to detect.swap the left and right steering hoses and see if the problem changes sides - if it does its the steering valve, if it remains the same side its likely the steering ram seals.
Aye, far easier on a test stand, only try that if you have a safe place to drive, away from others and safe for you. I have done it in a large car park before.I dont know if I will be able to drive it like that- it will be back to front? I have to be doing fast walking pace on road to really feel it. In bouncy fields on grass it's hard to detect.
My yard might do but each time I have driven across there it's felt OK till I get out on the road.Aye, far easier on a test stand, only try that if you have a safe place to drive, away from others and safe for you. I have done it in a large car park before.
Unfortunately with an internal leakage issue, pressure gauges are of limited help. With the front of the ground you will need far less pressure to steer, so fault will be less noticeable. Wider or twin tyres that increase steering pressure would show it more. Perhaps just try a hand pump on the steering cylinder and see if there is leakage out the opposite port, would be best done locking the steering in the central position, as that is where wear would be most likely. Sorry, wish I was near you and I would come and help.My yard might do but each time I have driven across there it's felt OK till I get out on the road.
Would pressure testing each side witb the front off the ground reveal the same thing if this chap I know has the gauges? I presume they will be a bit expensive to buy for this one off (I hope) task.
It's dawning on me that this tractor was sold as someone knew the brakes were breaking up and the issues that causes down the line. There are a number of JD threads on forums where folk have said change the oil and sell on quick!
