graffian
Seer unto the end of his beard
- gatwick
well i own a land rover! had a look at all the points identified and all seams fine. odd little bit of rust around windows on doors and in rear wheel arch. the chassis looks and prodded sound ant the bulkhead looks top condition including around the vents. couple of niggle bits to sort being window washer jets and working out how to get head lights on it still have the military switch and Infra Red switch the gear box is a bit hit and miss on gears but thats me not being used to old gear boxes any more!
Fill the vent panel with hot waxoyl. Mine looked great in 2000, not a single mark on it. A few years on the odd bubble appeared, now the inside seam is about an inch thick rust! The rear cross member outsides are blind and rust, wack some 20mm holes in the blind section and give that a good waxoyling, fill the 20mm holes with rubber grommets. Gear lever is usually tightened up a lot by fitting a new screw that stops the lever rotating. Sure there are plenty of other things people will suggest.
