Erie Fred
- Erie, Pa USofA
Yup, open top barrels in the streets fueled with old tires.....If the stove gets banned...won't people simply remove the stove and just burn on an open fire instead I'm wondering?
even the old style inset wood/coal fired chimney stove faces the fine so for those like me who have a chimney even i will remove the fire and build a fire within the chimneyIf the stove gets banned...won't people simply remove the stove and just burn on an open fire instead I'm wondering?
london has all the petrol/diesel fumes in the city so they will get enough of the bad air down there nothing like the old chimney firesIn the 60,s we had to go to school with jumpers over our heads because of the pea green fog...these pussy whipped politicians would not know bad air if it slapped them across there little pink arrsesThe air has never been cleaner and my stove is goin nowhere.
Marvelous !!! I remember having one of those in our home as a child - it was used for lighting the coal fire. What wonderful memories you have brought back to me - thankyou.My gran years ago had a gas poker, are they still around, not seen one in 60 years. I can’t see why one wouldn’t run off a propane bottle.
I am the originator of this thread "Log Fires - the future"![]()
New fines of up to £300 for using log burners
The aim of the fines is to reduce air pollutionwww.bristol247.com
bristol council newest ploy
Silver lining if you get a job as a chimney inspector!I am the originator of this thread "Log Fires - the future"
Maybe I'm a pessimist and can equally be accused of being negative but sadly - its coming isn't it? This is potentially a huge cash cow for Councils and I believe they will pursue it with some tenacity.![]()
im going to upset a few hereI am the originator of this thread "Log Fires - the future"
Now this is interesting - almost a full circle.It looks like allot of people can't (or don't care to) run a woodfire the right way ^^^.
So it smokes, they don't care, it's outside, they are inside.
I wonder if a pellet stove would work better for these people, as a PLC can be programmed to run it properly.
It could have intake air temp sensor, flow, stack temp, O2 sensor etc.
- to be able to reprogram the PLC, when it is smoking too much or won't start.....
Now we table the possible use of pellets/eco briquettes/biomass derivatives as a source of energy for our heating which, here in the UK, cost in the order of £400 (US$500)/per tonne plus delivery..... so I very much doubt if the numbers work here.
I just so much do not want that extra pain in my life.![]()
It is my understanding that the trend to run log fires was driven by economics and the fight to find a solution to negate the rising oil and gas costs - which, reading the comments on this thread, they appear to do so, on the proviso that you have a readily available (and free) source of suitable logs/timber. If you are not gifted with such a source - they apparently don't.
log fires was used as many like the flames of the stove im one of themNow this is interesting - almost a full circle.
Then we must consider the smart stove complete with PLC and ODB port so as you can download the faults codes, assuming you can afford the cost of the ODB reader and or the software on your computer - which will only run on Windows 7...- to be able to reprogram the PLC, when it is smoking too much or won't start.....
I had exactly the same thought. Add to that that we are just chopping down trees and not considering the next generation therefore not farming them (as you have pointed out before in other threads) and it makes it even worse.All a bit thought provoking, wondering now about the carbon footprint of the processed logs or pellets. Most of the log kilns I know of run on huge quantities of wet waste timber, add in all the mechanical handling and its not pretty, same for the pellets. Makes the man who cuts and stacks his own logs to air dry prior to use look like a love match for Greta Thunberg.
Bob
My house has an oil boiler. In winter we don't use it. The Rayburn runs all winter and heats the house (plus cooking and hot water). £5 a day for overnight coal roughly and free logs all day as needed, harvested from my own land and windfalls from a neighbour. What is harvested is either hedge (think big hedges) that are allowed to regrow or tree that has to come down (ash with dieback) that is replaced. Oil would be a lot more costly to heat this place - could be looking at £20 plus a day looking at old bills but thats all dependent on oil price.That is wrong, I'm the only person on this thread that has presented hard evidence and cost for a year on year comparison of using gas Vs gas plus log burner, and we have to pay the going rate for our logs. Go check out the post on the first or second page.
Add into that equation shipping the pellets across the world, just to burn them…..andit becomes complete madness.All a bit thought provoking, wondering now about the carbon footprint of the processed logs or pellets. Most of the log kilns I know of run on huge quantities of wet waste timber, add in all the mechanical handling and its not pretty, same for the pellets. Makes the man who cuts and stacks his own logs to air dry prior to use look like a love match for Greta Thunberg.
Bob
Funny we have this set up, it works in a fashion, but the back boiler operates at 55 to 60 degrees, the boiler at 85…so once the fires on, the boiler is off, or the fire would choke its self back to prevent it over heating, so become inefficient. Only last night we were discussing removing it and going to a stand alone multi fuel stove. The extra pumps also consume energy, not sure about 800watts or so. In a power cut we use the generator so just put the heating on.ETA - when we installed the Rayburn, the thermal store was also specced for an input from a log stove with a back boiler. I may not go this route as we dont use the lounge every night (as the kitchen is warm) and the run is too convoluted to do by gravity alone therefore it would mean no use of the log burner in a power cut - which is very often when you might most want to use it! The Rayburn is fine in a power cut as the water is gravity fed to the thermal store from the back boiler and all i need to do is run some hot water to cool the store down (so basically just have a bath...)
Our setup is such that the central heating pump circulates once that level in the thermal store reaches 55C. It keeps the water returning back to the Rayburn cool enough that the rayburn damper (the thermostatically controlled one) stays open unless it gets really warm for some reason. It works quite well and continually circulates the rayburn heat around the house. If i really ramp the Rayburn up it can send temps of 85+ up to the thermal store so can go a fair bit higher.Add into that equation shipping the pellets across the world, just to burn them…..andit becomes complete madness.
My conclusion there is no perfect solution normal folk can afford!
