dobbslc
- Hertfordshire UK
It was said that in the case of a nuclear ”event” the one thing that would survive would be cockroaches. No idea whether it’s true & I hope we never find out.I expect the cockroaches will take over.
Never trusted 'em.
Wont need to light the fire for a monthDrax is going solar and getting a 150MW battery, not sure how long it will be burning wood but I would be measuring it in months
Seriously though. How? Got a linky
Their so called Greens are just the anti nuclear lobby under a new hat. They obviously don't care or they wouldn't burn the stuff.Epic is size, not as in amazingly awesome (although they are a sight to behold, good or bad) maybe I should have used vast or enormous instead…
That lignite stuff is horrible, I can’t believe they still burn it…
We burn a mix of logs and those ovaloid coal replacement things. Its a boiler stove soheats the whole house when its on, also adding enough heat during the burn to sustain the UFH most of the following* day unless it's balticI haven’t read through all 5 pages of this thread but, I’ve had a log burner for the past 7 years, saves me a fortune as I only need the central heating turned up to 18 degrees this year, last year it was 17 due to the price of gas. The stove means the living room is toasty the rest of the house reasonably comfortable.
The first couple of years I was a wood slave, sourcing, chopping, seasoning about 15 cubic metres of wood, now I use a combination of smokeless fuel with a log chucked on top, the wood I get for free, easy when you have a trailer, a ton of smokeless fuel is about £630 and will last more or less a winter, reduced wood consumption by about 2/3rds, this year I also got a half ton of peat, it’s ok, but leaves a lot of ash after it’s burned.
The money I spend sounds like a lot but last winter my gas and electric was over £700 per month so a grand on smokeless fuel and peat over the winter is a significant saving on what it would cost by not having the stove and turning the heating up another 3-4 degrees.
I looked at coal but it was no cheaper than the smokeless fuel which I think comes from South America, so it has a carbon footprint just to get it here
Is that a typo....or do you live in a castle?The money I spend sounds like a lot but last winter my gas and electric was over £700 per month
Yes with hindsight when I installed the stove I’d have it plumbed into the CH, I did look into it but the process seemed a bit complicated at the time and it’s not my area of expertiseWe burn a mix of logs and those ovaloid coal replacement things. Its a boiler stove soheats the whole house when its on, also adding enough heat during the burn to sustain the UFH most of the following* day unless it's baltic
No it’s not a castle or a typo, house is detached, exposed and Edwardian so not insulated like a modern house.Is that a typo....or do you live in a castle?
As most of the country is run by them I don't expect we will notice the change presuming we also survive.It was said that in the case of a nuclear ”event” the one thing that would survive would be cockroaches. No idea whether it’s true & I hope we never find out.
Yes spruce needs to be well seasoned, once chopped into logs and stacked I’d say 12 months, pine can be like that also, lots of sap which needs to be dried offweve got a fair few crappy sitka spruce trees that were planted in the 1940s that I'm using as firewood. It's crap firewood and burns away to nothing but it's free and the trees are in my way. Doesn't split very well either. I'm going to have to get someone in to take down some of the big ones as I'm not sure I'd manage to do it safely. Probably end up in local paper, idiot blocks road with tree or something. Some of the must be 70 or 80 feet high and are over 40 inches dia.
Yes, leave it out in the rain one winter at least before drying.Yes spruce needs to be well seasoned, once chopped into logs and stacked I’d say 12 months, pine can be like that also, lots of sap which needs to be dried off
Not much out in public, mentions Ferrybridge but that's just part of it, the whole Drax, Ferrybridge, Eggborough, Salt End and some in NE Lincolnshire are part of a huge project getting underway
Projects | SSE Renewables
www.sserenewables.com
Better than nothing but a log store would be betterYes, leave it out in the rain one winter at least before drying.
