Please tell me that lot has got to be for business use, no one can have that many toys can they?
Wow, and I have to use a tiny 1930's garage, I drove a Mk2 Escort in once and found that I could not even open the door to get out of the car and I was a 12 stone weeklin in those days.Not for commercial use , its toys only. I am trying hard not to mix the two because it gets in the way of playtime.
Bob
Security suggestions if you haven't already considered it .
Put side slide bolts in at the bottom of the shutter . Use a decent close shackel clamshell padlock in the chain to stop anyone raising the shutter with a spade in the middle , enough to slide in a scissor jack. Locking the chain also heps delay & or upset thieves if someone takes out a few TEC screws and lifts a roof panel etc & get inside whilst an alarm is sounding off .
If you have an alarm wirer in a proximity magnetic reed switch in either side of the door frame screwed into the floor or the frame & put the operating magnets on the roller , so that it breaks the monitored circuit if the roller door is lifted when the alarm is set ,
Put side slide bolts in at the bottom of the shutter . Use a decent close shackle clamshell padlock in the chain to stop anyone raising the shutter with a spade in the middle , enough to slide in a scissor jack.
Locking the chain also heps delay & or upset thieves if someone takes out a few TEC screws and lifts a roof panel etc & gets inside whilst an alarm is sounding off .
If you have an alarm wire in a pair proximity magnetic reed switches one either side of the door frame ,screwed into the floor or the frame & put the operating magnets on the roller , so that it breaks the monitored circuit if the roller door is lifted when the alarm is set ,
i recently installed a 8x8 insulated roller door and i was thinking only the other day that it was a weap point in the scheme.
the sliding bolt idea is a good one but id like to still be able to open the door on the fob alone.
i suppose electric bolts would be the route there, i must look into it, its a good plan.
i never sat down to think about it but what would a man need if he wanted to made a basic alarm that would kick off if there was movement after hours, id like to be able to be reset if it happened to sound if a bird set it off by accident without the need to open up, range there would need to be about 100'.
i loud siren, a few sensors, cable, fob, controller??
Mancave was hammered last night in the winds, still there so all good No urlektrishuns have come forward with a wiring diagram for the leccy door yet, come on chaps.
Bob
sorry, assumed you only had the door and were going to wire it straight to the switch
which controller do you have ? need photos of that too, some use limit switches some don't
looking at the motor, one of my roller motors is identical by the look of it
you can use either can switch for up or down, the cam's are adjustable, little alan key and you can spin them around to where you need them
controller will have 3 wires for limit switches
your feed needs to go in on the far bottom left connector number 1 (above the wire with the gray crimp on it)
then you have 2 returns, then go in number 2 and number 5
tricky to tell from the photo, but it looks like some of the wires pass straight through and out the bottom ? - guess they're going to the motor ? (my motor is wired differently)
take the cover off the motor and see which wire goes where (cores are numbered)
