Is this roller shutter door single or 3-phase?
Someone I know reckons it looks like a Garog btw.
Hi, The phenomenon is not unknown and it can interfere with PIR's in that they come on then won't go off again.
Colin
. Its oil based and the cladding only needs to be clean, I will try a test piece of about a square meter with the anti condensation dust added and see how it performs.
if they're the normal cheap Chinese LED floodlights it's the transformers/led driver inside them, not enough capacitors and/or they're too small/cheap
could be just one of them is the culprit, or one is worse than the others... or they're all terrible
if you can plug the radio in on a different circuit it might help - if you have 3 phase power it from a different phase
(but no grantees it'll make any difference at all)
And then I might get my router backcan then put up the ply and insulation
And bought a few of these Reventon 22kw heaters which circulate the air, again should help to keep condensation at bay.
If you have one put the lights on one of the computer mains surge filter block of plugs and see if the problem remains ..or if they are already wired in try plugging the radio & /or TV into one , if it is mains borne interference it may reduce it .Useful info Colin, thanks.
Is this because the radio is plugged into the same circuit or is this some other oddball interference,is there a way around this? I know its only temporary but the same lights will go on the outside at a later date, I wont bother if its going to play havoc with the telly or radio.
Bob
You can buy what is known as a Roxborough filter as well for places like RS on line they give a really good clean 50 cycles at 240 volts .
@8ob @brewdexta
Just been reading the manual for those Reventon heaters, the look ideal for a workshop even more so if you have a cheap source of fuel. They aren't that expensive either.
They would be ideal for someone with a garage integral/joined to their house as it would be easy to tap into the heating system.
From the manual it looks like the fan speed is variable and can be used for cooling too.
